Old 08-25-2017, 01:43 PM   #1
a Good Man
a Good Man's Avatar
A question about gmc 1969
Hi
I have a question . Is it possible to convert Mechanical oil gauge
To
Electric oil pressure gauge ؟
I want the same gauge but electrician
MY Facebook
( saad_alhajri ) on Instagram
a Good Man is offline   Reply With Quote
Old 08-25-2017, 01:56 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: A question about gmc 1969
Good question, I wish I had a answer for you.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-25-2017, 06:16 PM   #3
jeffahart
jeffahart's Avatar
Why do you want to convert? A VDO with a 10-2 Oclock might be close enough to stick your stock face on.
Good luck, post your solution if you hassle with it.
j
White K20
jeffahart is offline   Reply With Quote
Old 08-25-2017, 06:35 PM   #4
a Good Man
a Good Man's Avatar
j
Welcome sir. Conversion means the end of leaking oil inside the truck. Many of us suffer from this problem and want a solution
MY Facebook
Old 08-25-2017, 06:44 PM   #5
jeffahart
jeffahart's Avatar
For sure. I've only had issues with the aftermarket plastic lines with compression fittings. The steel hard lines in the 70 is good setup, no leaks. But if you are doing Class A resto and have had leaks in other setups then I can see your apprehension. But if you don't convert, you can rest easy; because I don't think you will have any trouble with a quality reproduction hard line.
j
White K20
Old 08-25-2017, 06:59 PM   #6
a Good Man
a Good Man's Avatar
j
Do you have an example of this? thank you for your reply
MY Facebook
Old 08-25-2017, 07:08 PM   #7
a Good Man
a Good Man's Avatar
j
Sir I do not have a problem with the leak now but I'm looking for a new solution. Suppose there was a leak Why wait for this to happen? The best solution now is electrolyte, do you agree with me?
MY Facebook
Old 08-25-2017, 06:36 PM   #8
a Good Man
a Good Man's Avatar
thank you my dear
MY Facebook
Old 08-25-2017, 06:57 PM   #9
a Good Man
a Good Man's Avatar
https://www.howacarworks.com/accesso...re-gauge-works
MY Facebook
Old 08-25-2017, 10:00 PM   #10
garyd1961
Mine has been working since 1970, no leaks yet but if it starts I'll replace the lines. Then I should be good for the next 50 or so years.
garyd1961 is offline   Reply With Quote
Old 08-27-2017, 08:26 PM   #11
87Skier
87Skier's Avatar
I don't know if this will work, but if you are looking for a possible solution, you might be able to use the later style oil pressure gauge from a truck or suburban. My 89 suburban (below) has one of the electric units, and that is a fairly common swap for the volt gauge.
If you grab the oil pressure sending unit off the newer engine, the block should be the same, so it would just be a matter of connecting up the wires and tapping into power off the rest of your gauges.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 08-28-2017, 12:51 AM   #12
a Good Man
a Good Man's Avatar
Exactly what we are doing now I will show you the results soon . I always think there is a solution no matter how difficult. The important thing is to get a result that serves a lot here
MY Facebook
Old 08-28-2017, 03:22 PM   #13
MARKDTN
You might try a high-end gauge restorer like "Corvette Clocks by Roger" in Jackson TN. They could possibly convert it.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-28-2017, 04:01 PM   #14
HO455
HO455's Avatar
The down side of going electric is the loss of accuracy. Every connection adds resistance and that affects the guages reading. It is the same issue with the factory water temp guages. That is unless you step up and go to a late model 5 volt PWM sensor and guage set up. But then you will need some sort of computing power.
That seems like a lot of effort to avoid a maybe leak that most likely could be avoided by cutting the factory steel tubing off at the old ferule and correctly installing a new ferule. But that is only my opinion.
RIP Bob Parks.
