Old 08-29-2017, 10:11 AM   #1
s10mk
overdrive manual transmission options?
Hello,
To my knowledge, there are three good options for an overdrive manual trans.
1. Ranger overdrive coupled with sm420/ sm465
2. Nv4500
3. T56 with midshift kit.
I didn't include the gear vendors, only because at $3k, it's a little out of my price range. And I wouldn't consider the nv3500 due to durability issues.
Am I missing anything?
Out of the three options I listed, what are the pros and cons? what has worked the best for you?
2009 GMC Sierra 1500
2006 Buick Lacrosse
1987 Chevrolet V10
1972 Chevrolet c20 350/350
1967 Chevrolet Biscayne ls3 swapped
s10mk is offline   Reply With Quote
Old 08-29-2017, 11:10 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: overdrive manual transmission options?
Originally Posted by s10mk View Post
Hello,
2. Nv4500
This is how I replaced my SM465 with an NV4500 in my '72 Chevy Dually.
http://67-72chevytrucks.com/vboard/s...d.php?t=673588
That was in 2015 and it is still working great today....
LockDoc
Leon
Old 08-29-2017, 11:57 AM   #3
68GRNK20
68GRNK20's Avatar
I'd go with the NV4500, the NV3500 is a good transmission if you are not using your truck for too much work, it is a medium duty and only rated for 300 ft/lbs
I wouldn't bother with add on overdrives the seem expensive for what your getting and unless you really want to keep your transmission that you have already.
68GRNK20 is offline   Reply With Quote
Old 08-29-2017, 12:39 PM   #4
Bigdav160
Bigdav160's Avatar
Define "good options"
4x4 selection is really limited. 2WD less so.
You left off the T-5 and the A-883 (which was available with an overdrive).
Also there are a few aftermarket solutions.
edit: I didn't see that you put the NV3500 in the bad option list so the weaker T-5 would also be out.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-29-2017, 01:51 PM   #5
HO455
HO455's Avatar
Here is a good site for some research on the subject.
https://www.novak-adapt.com/knowledg...ssions/manual/
RIP Bob Parks.
Old 08-30-2017, 07:46 AM   #6
s10mk
Sorry, I should have been more specific about "good options". I would be looking for something that can be easily swapped into a 2wd truck. I'm not concerned about getting a new driveshaft or trans crossmember, that stuff goes with the territory. But a good option would come with minimal or no cutting of the floor, I would like to still be able to use a bench seat, Overdrive, durable, And preferably a mechanical speedometer.
2006 Buick Lacrosse
1987 Chevrolet V10
Old 12-21-2021, 10:51 PM   #7
jocko
jocko's Avatar
"Durable" is a tricky word... A T5 is very durable if you aren't towing or doing burnouts. If you are doing either, it is not. What are your intentions for the truck and how do you want to drive it? I'm assuming that since you mentioned durability - you intend to abuse it a bit - but I don't know that - can you elaborate? The answer could drive your selection since budget is an issue. Some of the options listed may eclipse the cost of a GV unit - which you've already ruled out due to cost (and it is likely the most durable chunk of metal in this whole thread) - so, again, interested to hear your intended use/environment for the trans. (if you do intend to do burnouts routinely, then you're on the right track and have already eliminated the right stuff )
Old 12-21-2021, 11:13 PM   #8
davischevy
davischevy's Avatar
This thread is older than one of my jokes, but I'll throw my two cents in.
I recently installed a Gear Vendors Overdrive and love it.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 12-23-2021, 10:52 PM   #9
Sheepdip
Sheepdip's Avatar
The only way to Fly! Got two, one in a 49 Chevy PU behind a TH350 and one in my Avatar Otis behind a SM465. The ability to split several gears is way better in my book especially when loaded or towing.
Sheepdip is offline   Reply With Quote
Old 08-29-2017, 02:50 PM   #10
Keith Seymore
Keith Seymore's Avatar
I'm a huge fan of the New Process A-833 (RPO MY6).
250,000 miles on mine with no issues.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-29-2017, 03:18 PM   #11
s10mk
K
Well I'm certainly happy I started this thread, I've never heard of that transmission. Thanks know you much!
2006 Buick Lacrosse
1987 Chevrolet V10
Old 08-29-2017, 03:42 PM   #12
bw46
bw46's Avatar
I have a TKO600 and I'm not very impressed with it. the case leaks a bit from the factory (I bought it new), it's kind of noisy in 4th, and the 1st to 2nd shift is slow and cumbersome. Maybe I got a lemon, who knows. I do like the 5th gear overdrive, it's smooth and quiet.
For reference, I have this installed behind a BBC in a 66 2WD
bw46 is offline   Reply With Quote
Old 08-29-2017, 09:24 PM   #13
RustyBucket
RustyBucket's Avatar
I'm surprised & sorry to see your not happy with the TKO600..... I have a TKO500/mild 454 combo in a '72 2wd Blazer and I like it a LOT. I don't full throttle shift it but I do pull 2nd pretty hard sometimes showing off and it does fine. Reverse is a little noisy. 3.27 first gear ratio is pretty steep but would be good to get a loaded work truck rolling with a 3.73 rear gear. My Blazer has a 3.08 open rear and no traction in first gear. 80mph in O.D. is about 2000 rpm. Hydraulic clutch linkage is smooth and low pedal pressure . Real pleasant to drive.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 08-29-2017, 10:45 PM   #14
davischevy
davischevy's Avatar
K
Keith, is that a 4 speed overdrive? What vehicles was it used in?
other Larry
Old 08-30-2017, 06:17 AM   #15
s10mk
From what I read, it was used in Chevy trucks from 81-87 in 2 and 4 wheel drive. And yes, it was a true 4 speed with an overdrive. Rpo code my6. But the a833 was originally used by Chrysler in the 60s
2006 Buick Lacrosse
1987 Chevrolet V10
Old 08-30-2017, 07:31 AM   #16
Keith Seymore
It's three forward gears plus the overdrive.
It is a MOPAR trans with third gear set 1:1 and 4th gear as .73:1 (or .70:1 - I never can remember). The factory shifter was provided by Hurst.
Mine is an '87, and I ordered it specifically.
K
1979-1986
1986 - 2019
Old 08-30-2017, 07:43 AM   #17
s10mk
K
HI keith, I'm assuming that it also uses a mechanical speedometer drive? That would be having my cake and eating it too
2006 Buick Lacrosse
1987 Chevrolet V10
Old 12-23-2021, 08:21 PM   #18
BASE
BASE's Avatar
Reminds me that I saw one on CL locally here a while back that had me scratching my head. He's calling it a NP440 but mentions RPO MY6 and it apparently is an OD manual out of an '87.
Still there: https://stlouis.craigslist.org/pts/d...398930026.html
I think this must be the same critter as what you are talking about.
BASE is offline   Reply With Quote
Old 08-29-2017, 04:01 PM   #19
clay68c10
clay68c10's Avatar
The TKO 500 is a good option, the 1-2 ratio split seems like it would be good for most uses and the overdrive is fairly steep.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-29-2017, 10:09 PM   #20
In The Ten Ring
Is there an overdrive available for a 3OTT? I love my column shifter but could use another gear (or two).
In The Ten Ring is offline   Reply With Quote
Old 12-21-2021, 10:38 PM   #21
69TowRig
Possibly, I just finally found a Borg Warner overdrive with the Rancho adapter on it for the Dana 20 transfer case in mine. If yours has the Dana 20 then you can start searching for one of these. It's old stuff but I really want to keep the SM-330 column shift so this was the only option. Rancho sold them for Jeeps, Broncos, and Scouts. It uses either the B-W R10 or R11 overdrive. Only works in 2wd.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 08-30-2017, 09:13 AM   #22
randy500
Pics of the mY 6 are here, it has a mechanical speedo
https://67-72chevytrucks.com/vboard/...=574221&page=5
randy500 is offline   Reply With Quote
Old 08-30-2017, 01:44 PM   #23
Keith Seymore
Mine has a mechanical speedometer.
K
1979-1986
1986 - 2019
Old 12-21-2021, 11:27 PM   #24
jocko
jocko's Avatar
I feel into the time warp, hook, line and sinker! Ha.
Old 12-22-2021, 09:48 AM   #25
69TowRig
Yeah I knew the comment would come up on a four-year old thread but I was searching around, found this thread and saw that the one question wasn't ever answered so I threw my two cents in as well. I am super excited about finally finding one of these rare items so that my Blazer isn't screaming keeping up with modern traffic.
-Chris
