09-01-2017, 11:53 AM | #1 |
Front drive shaft hitting trans pan
Has anyone had this issue when re-installing your front drive shaft on a LS swap? I'm wondering if the transfer case has enough play to rock towards the passenger side a bit. Just the corner of the shaft is hitting the corner of the trans pan. It's a new drive shaft and seems a little beefier than the original one, but I wanna see if any of you have run into this and what you did to fix it. I know there are some threads on this subject, but since most were several years ago, just seeing if anyone has come up with new solutions.
1972 GMC Jimmy 6.0/4L65 1972 Chevrolet long bed 1/2 ton Last edited by GM man; 09-01-2017 at 12:02 PM. Reason: additional comment |
09-01-2017, 03:35 PM | #2 |
Re: Front drive shaft hitting trans pan
It appears that your u-joint yoke is wider. If so, why? What series u-joints are those? 1310? 1330? 1350?
09-02-2017, 01:11 AM | #3 |
I've seen this before. I believe most who did the swap clearanced the pan.
Kirk 72 Blazer CST 4wd highlander |
09-02-2017, 10:36 AM | #4 |
That is a 1310 u-joint so like was mentioned earlier you will need to clearance the pan.
09-03-2017, 12:45 AM | #5 |
I'm not sure what series u-joint this is. The shaft is from Napa and is what they listed as a replacement. The diameter of my original yoke looked a little smaller overall than this one, but if it cleared the pan it would only be a fraction on an inch, which I could see potentially being a problem. When you guys are saying "clearance the pan" are you talking about shaving the corner of the pan off as much as possible?
1972 GMC Jimmy 6.0/4L65 1972 Chevrolet long bed 1/2 ton |
09-03-2017, 11:42 AM | #6 |
You can clearance it the hillbilly way by whacking it with a hammer, or in my opinion, the more acceptable way by cutting the corner off and welding a patch.
Just make sure to get enough clearance for when you stuff the passenger front tire or it may hit the pan.
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744 |
