Shock Torque Specs Confirmation
Was reassembling and torquing down the rear suspension on the C10 and just can't get over the torque specs for the shocks ... 130-150 ft. lb. for the upper eye and 55-75 ft. lb. for the lower. The upper mounts were pinching the heck out of the bushings and I still had a ways to go, so I stopped and moved on because it just didn't feel right. I know they're book torque specs, but would feel better if I heard from others confirming they ratchet down that much on the shocks.
My truck ain't dead, it just smells funny. |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Shock Torque Specs Confirmation
http://www.chuckschevytruckpages.com...que_specs.html
Ya that does "seem" rather high but thats what the chassis torque specs show. 1/2" grade 8 fasteners torque at 90 foot pounds and 5/8" grade 8 are 159/180 ft lbs. So I guess they're using the 5/8 size fasteners? Maybe someone in engineering can assist. ![]()
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 09-04-2017 at 07:28 AM. |
#3 | |
![]() Join Date: Jan 2011
I think that spec is for the big nut on the back side of the upper shock mount stud and no the nut that goes on the shock end.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Thanks for the replies. I started cranking down to spec and it looked so bad I backed off and tightened all to 45 ft. lb. I did a little reading and it appears there's 2 bushing styles and I'm pondering if the previous owner installed shocks with the non-stock style bushing, hence the brackets pinching like heck.
