10-27-2003, 06:23 PM | #1 |
71 GMC 1 Ton Dually Rear Axle
My 71 GMC 1 Ton 7200 lb axle is tossing rear end 90w all over the brakes on the right side. I've had the hub seal replaced but it's just not sealing. Now what do I do? ... Replace the rear end?
I've put about 65-75 miles on it since I had the hub seal replaced and it's just as bad as before the seal was replaced. If I need to replace the axle does anyone have a source for a rebuilt one? |
10-27-2003, 06:42 PM | #2 |
68cst_ss490
see if u can buy a stemco seal for it
the axle stub where the seal rides probably is scored the stemco seal comes with a wear sleeve that u put over the stub where the seal rides. this should cure your problem
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
10-28-2003, 07:08 AM | #3 |
Dean23,
Thanks, I found the Stemco web site and it looks like their Grit Guard #392-9063 is the one I need. I'll give them a call and see if they have a distributor in my area for it. |
10-28-2003, 11:38 AM | #4 |
MOVE OVER
TreverSlyFox,, WoW, Houston, MO, Thats my old stomping grounds... I grew up in Plato, and go there every other weekend to help my Dad with his place.. still go to Houston now and then to get auto parts..... Got any pics of your dually? I've got a 67 C-20 that I want to put duals on soon still at his farm...
No matter where you are..... There you are... Buckaroo Banzi |
10-28-2003, 07:50 PM | #5 |
"Ochre Ogre"
Your next choice is to have a 73+ 1 ton dually rear installed. If you take a look at your drums and find they are worn out or if this sleeve doesn't work, you will have to do that anyway. Just try and find a good set of drums for a Eaton/Corp rear 31 years after production stopped.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
10-28-2003, 09:21 PM | #6 |
da-burb is right belives me it's hard to find a good drum after 31 years...here you have to have 1 ton duallies here inspected every year to keep them on the road or there considered not road worthy and they wont give you license plates or insurance ........so your sidelined till you find a good drum if it dosen't measure within tolerances. Its a big fear I have with my tow truck.. what happens when my drums dont pass.......well I have it figured out as we have some aircraft industry here and they as well as some machine shops have a metal spray ( flamespray) process that will layer a little thickness to the drum and then you can cut it to nominal size.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
06-25-2013, 05:32 PM | #7 |
Re: 71 GMC 1 Ton Dually Rear Axle
I have a problem, I am trying to remove 73 GMC 1 Ton Drum Brakes in the rear, And I can not get them to budge. I have tried everything. I noticed there is a weird ring where the axle sits within the the axle case. I don't know if I should tap it out or leave it there. The Brakes on this truck have never been changed. It should be a 3/4 ton, however, the 1 ton was put there so I could haul 5th Wheel's and other Goose neck trailers.
RoughKuntry 73 GMC 25 HUNDRED :Sold 79 GMC High Sierra 4x4 (Ma-Duece) :Sold 99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling 88 Chevrolet Burban 2500 4x4 :Buying |
