![]() Join Date: Feb 2009
Carrier bearing mounting bolts, cotter pin bolts?
Just curious if the carrier bearing mounting bolts are supposed to be cotter pin bolts. I don't see a good reason for cotter pin bolts.
As I found them, there was a bolt and washer below, and a lock washer and nut on top. There were no cotter pins, though one bolt had what was left of one. Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Jul 2016
Re: Carrier bearing mounting bolts, cotter pin bolts?
Fine thread too, right? They always have those but I have never seen cotter pins in the holes...
Who Changed This?
![]() Join Date: Jan 2013
Welcome back, Kotter! Couldn't help myself. Nope, no Cotter pins required in that application. Looks like someone went in and did a little dirty work at some point.
#4 | ||
![]() Thanks for the responses.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-11-2017 at 09:50 PM. |
One of the First
![]() Join Date: Jan 2000
That is correct for that size. I have the same bolts on my C30 carrier bearing
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
Those are the right bolts and nuts. I guess maybe they had voter pin sin them from the factory, I just don't ever remember seeing them.
I lost one of those oddball nuts a couple weeks ago...I know the direction it went so I guess it will turn up. |
I imagine you're like me "I got to find that nut". I was thinking the bolt head was irregular, but I see you're right, it's the nut.
I dont think a cotter pin would be as effective as a lock washer in that application. I have had several of these trucks and never observed a hole in the bolt for a cotter pin used in that location. so dont read too much or over analyse the hole deal.
