09-14-2017, 03:20 PM | #1 |
Fender Removal
I've searched through this forum for how to remove front fenders on my '72 GMC P/U
and can not find any information on how to do this. Please someone point me in the right direction on how to remove these. Thanks, slowboy |
09-14-2017, 03:33 PM | #2 |
Re: Fender Removal
Hi slowboy,
I found this info on the forum a while back, so I'll pass it on. These two images show how the fenders bolt up to the fire wall. You do need to remove the cowl to get access to one bolt, and the door must be open to get access to a couple more. When you look at the under side of the fender you will see the bolts that attach the inner fender well to. There are a couple more bolts that go into the core support that were easy to find, I don't have an image for them. |
09-14-2017, 04:40 PM | #3 |
Re: Fender Removal
Thanks for reply 'outfield'...
...so can fender/s be removed without removing inner fender/s...just remove cowl and hood?... |
09-14-2017, 04:46 PM | #4 |
Re: Fender Removal
Yes, you can remove the fender and leave the inner fender in place.
I just replaced my passenger fender and left the inner fender in place. We unbolted the hood hinge and rested the back of the hood on a 2x4 that sat on top of where the cowl was. (by the wiper arm pivot) Then unbolted the fender and removed it. |
09-14-2017, 04:47 PM | #5 |
Re: Fender Removal
yes, that is correct.
09-14-2017, 05:32 PM | #6 |
Re: Fender Removal
Thanks for reply guys!!
09-14-2017, 05:49 PM | #7 |
Re: Fender Removal
It's easy, once you get it going. I removed both of mine with just a 3/8" ratchet set.
Let's see, you have a total of 11 bolts to remove. The three at the rear are one size larger than the 8 at the front, plus ever how many attach the inner fender to the outer. You may break a couple of bolts, I did when trying to remove the outer from the inner. If that happens you may have to remove both the inner and outer at once. Last edited by In The Ten Ring; 09-14-2017 at 08:44 PM. |
09-15-2017, 03:54 PM | #8 | |
Re: Fender Removal
09-16-2017, 08:05 AM | #9 |
Re: Fender Removal
I have LH Fender loose. Seems that either grill, or bumper is preventing me from completely removing fender.
Any help/advice appreciated please. Thanks! [don't want to remove anything unnecessarily] Last edited by slowboy; 09-16-2017 at 08:27 AM. |
09-14-2017, 08:40 PM | #10 |
Re: Fender Removal
Is the bracket, #1 in the illustration, a GMC only thing? My '70 Chevy does not have those
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
09-14-2017, 08:44 PM | #11 |
Re: Fender Removal
My 1972 Chevy does not. My fender was easy to remove, except that the inner fender had to come off with it, and to do that, I had to cut off the inner from the core support, as it was so rusted the bolts broke the core support and were "free wheeling," and unable to remove.
09-15-2017, 03:14 PM | #12 | |
Re: Fender Removal
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
09-15-2017, 08:10 AM | #13 |
Re: Fender Removal
I started removing the bolts for LH fender well outside and 2 of them want to just spin. Do they screw into one of those metal clips? I'm wondering if clip came off or broke.
09-17-2017, 11:21 AM | #14 | |
Re: Fender Removal
I use a pair of small vice grips to grab them from the back side. It ain't easy, but possible.
09-17-2017, 12:08 PM | #15 | |
Re: Fender Removal
*Pretty neat about the GMC grill and fender not overlapping. Yesterday I was cleaning up my garage a bit and FOUND PART OF A J NUT THAT HAD BROKEN OFF. Crazy. Original poster: just keep taking bolts off and you'll get there, figure it out as you go. |
09-17-2017, 02:14 PM | #16 |
Re: Fender Removal
Take plenty of pictures. You will thank yourself later.
09-17-2017, 03:36 PM | #17 |
Re: Fender Removal
Yes, this!
Also put every bolt you take off into a plastic ziplock bag with a label. I did that and I cleaned up every single bolt and fastener. I ended up using new bolts but only because new ones have a coating on them. I have reused some old bolts but it was easy because I had everything labelled. I took a ton of pics also but those haven't been that important, you'll remember most everything when you go back, I have at least. I still recommend taking lots of pics as you take it apart. |
09-15-2017, 10:11 AM | #18 |
Re: Fender Removal
There are j-nuts that the bolts thread into (metal clips). You will be lucky if only 2 of them break on you. Most of mine did when I removed the original fender. You can get them at NAPA, part number 665-1052, they come in a pack of 7, or any j-nut for 5/16-18 thread will work. I ended up removing the inner and outer fender together because of this problem, then was able to get the old j-nuts off the bolts.
09-15-2017, 12:36 PM | #19 | |
Re: Fender Removal
It's a "job" for a single person but it's do-able for sure. I did it in the tight confines of my garage. |
09-15-2017, 03:16 PM | #20 |
Re: Fender Removal
Learn something new every day! Thanks for the info Roger.
09-17-2017, 10:46 AM | #21 |
Re: Fender Removal
You can pull a GMC fender (or a 67-68 chevy fender for that matter) without pulling the grill because they don't overlap the fender like the 69-72 chevy grills do. I've done it tons of times, but I think I always had the front bumper off.
Good luck, Rg
