Weekend Project - Fuel Tank and Steering Column
I received a rebuilt steering column from Kev's Classics and a an OEM fuel tank from Classic Industries. I will be replacing both this weekend and wanted to know if anyone has any advice, do's or don'ts for these projects. Thanks for the help.
Re: Weekend Project - Fuel Tank and Steering Column
Don't smoke. And do use wd40
61 apache |
The fuel filler rubber hose is not easy. Be patient, get a new hose, and review your cuss word inventory- you'll need it.
Everybody has to believe in something. I believe I'll have another beer. |
I cut my finger trying to replace the fuel hose.
One foot in front of the other
![]() Join Date: Aug 2008
The gas tank install is much easier with the seat out.
Us old guys forget how stuff goes back together so take pictures of how the original column is installed before taking it apart. Replace rag joint. |
![]() Join Date: Jun 2015
When unbolting the rag joint from the steering box - completely remove the bolt, don't just loosen it. Sometimes the bolt itself without any tension on it is enough to keep the rag joint stuck on the splines.
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
Show some pictures if you can so others can see if thay have any questions.
