09-16-2017, 07:28 PM | #1 |
650-1000hp goals? Need help
I have a 1972 suburban that I would like to build an engine that puts out 650-1000hp that I can daily drive. The issue I'm having is what motor I want/should build. I have a 4 sbc, 1 bbc mark lV, a bbc gen 5 long block and a bbc gen 6 with a bad block. And if I should keep it N/A or turbo it.
What is everyone's opinions?
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank. 70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank Dads: 67 c10 step side(project) 72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter) Ours: 67 c30 tow truck 70 c10 long bed 383stroker w/digital gauges(work truck) |
09-16-2017, 08:16 PM | #2 |
Re: 650-1000hp goals? Need help
650 is one thing and a 1000 is another thing. Just the racer in me but for that level I would be looking at an aftermarket block along with the rest. You need to decide early on boost or NA. Everything gets built around that choice. Boosted will get you there with less cubic inches. Then there is everything that goes with it, trans, drive line, chassis and brakes.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-16-2017, 08:23 PM | #3 | |
I know an aftermarket block is the way to go in the long run but I want to start with what I already have
09-17-2017, 12:13 AM | #4 |
meowMEOWmeowMEOW
@ 650, small turbo LS motor, do it cheap and beat it like a cheap wh*re.
@1k then its a budget question. We do LS stuff north of 1k all the time, but depending what you wanna do with it, it might not be the best option. If you want the "easy" 1k with room to build and can cut the check, then its the aftermarket bbc discussion; big cubes etc, big heads, big fuel. We live in a world where Sonny Leonard will sell you a 700+ci motor
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
09-18-2017, 07:48 AM | #5 |
Here is an example of a pump gas 1000HP BBC. http://www.sonnysracingengines.com/e...-racing-engine And the economy version. http://www.shafiroff.com/chevy-crate...isted-sr20.php Then easily 15K for what goes behind it and around it. Pick a goal, plan carefully and work out a budget. Build the best you can with what you have to spend.
Jimmy
09-18-2017, 08:29 AM | #6 |
Registered Truck Offender
Yup ot's only $$$$$$$$$$$$$$$$$$$$$
Heres a big block for ya,, on EACH SIDE,, 904 cu in. This ones in the 3000+HP range in a D bar D's nitrous Promod but point is,,, you can make just about anything these days if you have the $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ BR3 is the man,, Turbo LS is where I'd go too. My son is building 58 COE with a 415 C. In. LSx with a single 85mm turbo. Motor plan should have it around 650-700 on pump gas with streetable boost, and tickle 1000 with C-14. He's $12k into this motor in parts and pieces and it's not anywhere close to final assembly / plumbing / wireing if the motor yet.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
09-18-2017, 10:07 AM | #7 |
meowMEOWmeowMEOW
^^if he's running C-fuel for fun, have him try out Q-16. That stuff is WOW for race fuel. Chemically oxygenated fuel ftw.
09-18-2017, 05:02 PM | #8 |
I think he will stick with C-14 because it's the fuel i run in the Nova. (too easy access!!! LOL) I tried the -Q but just couldn't get the hang of the tuneup. We dyno tuned my motor on the engine dyno w/ C-14 so it it's easy to tweek for the air. But I just couldn't get enough Q fuel in it to make the motor happy. I'm sure he will have a MUCH easier time with the LS-
09-20-2017, 11:43 AM | #9 |
mini truck racer
I have a 2005 GMC RCSB with a 4.8 as a daily driver . I have been looking at a 70-76 mm single turbo set up at about 6 psi on 87 octane . I have been told I can make 550 to the ground and still get gas mileage and pull a boat or utility trailer like stock.
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
09-20-2017, 06:44 PM | #10 |
meowMEOWmeowMEOW
Nothing boosted on 87 octane will live unless your running methanol on top of it. ESPECIALLY for towing.
09-20-2017, 11:13 PM | #11 |
mini truck racer
So ford ecoboost trucks fail when towing ? Weird way of looking at things . you can make power with a low boost and the long block doesn't even know there is a turbo until you force boost . Oh .... and my low boost Ford has 302K on it .
09-20-2017, 11:26 PM | #12 |
mini truck racer
Guess I would love to see a drag strip test were pump gas and low boost failed bad . Also would be wouldn't mind see BR3W city actually making a good pass.
09-20-2017, 11:29 PM | #13 | |
meowMEOWmeowMEOW
Can you make a truck run on it? Sure, its fuel and its a motor. But you will either end up running it rich as hell to keep knock in check under boost, or end up keeping your boost at almost-not-worth-it levels. If you want to run methanol or something to keep it in check, great. Heck, you can probably go no-IC and JUST run methanol if your really content on ultra low boost. At least that buffers your Kr resistance. Get grumpy, wants to redirect
01-14-2018, 01:27 PM | #14 |
760whp on e85 here. I put on over 4000 miles last year, 1300 of it on race week, running 9s, and averaging 12mpg over the whole week.
very mild cam, forged piston and rod 6.0, billet 80mm turbo. very fun. but yes, 650 and 1000 whp is very different. the average Joe would brown their shorts with 450whp. Things can get out of hand very quick playing around on the street.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
03-22-2018, 08:37 PM | #15 |
I'm a bit late to the party but am making 590 hp, NA on 87 octane. 6.0 based stroker LS, all good parts and a really mild cam. Could easily make a lot more power but figured there was no way I could use it in a mostly stock suspension truck anyway.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
