09-17-2017, 03:56 PM | #1 |
Sealing Hood inner to the upper panel. INFO
I have a Hood that need to be sealed to keep it from rattling. The hood under inner panel is starting to let go of the upper outer panel.
It been a long time now I can’t remember what the black sealing stuff is called to keep the making noise . what company sell it. Or Part #?
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
09-17-2017, 04:21 PM | #2 |
Re: Sealing Hood inner to the upper panel. INFO
09-17-2017, 05:31 PM | #3 |
I used windshield urethane with no problems
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
09-18-2017, 12:32 AM | #4 |
RE-mongocanfly Perfect Thanks
