Old 09-18-2017, 12:38 PM   #1
jarrodblake
jarrodblake's Avatar
Manual transmission thoughts for HD car hauler.
I am in need of a new transmission for my 70 C30 it was a wedge truck that has been stretched into a dovetail truck with a 17ft bed. I believe the current transmission is the SM465 and it needs completely rebuilt or replaced. I would like to replace the transmission. My first thought was to replace it with a NV4500. However I am worried about the 5th gear issue. I know there are upgrades and supposed fixes. I have no problem not being able to use 5th gear when it's loaded up my main concern is, is it too heavy as is unloaded? I want to be able to use 5th gear unloaded. The way I see it, it is about as heavy as towing an empty HD trailer as it is. Or am I putting too much thought into it? Is there a better alternative for a transmission upgrade? I want to keep it a manual. That said it still has the original 350 engine in it and it this time I don't plan on swapping it out. Though I have had the thought of throwing on a 671 blower on it, but only time will tell what I end up doing with it. So do you all think I will have any problems with the NV4500 unloaded? I plan on doing the fixes to it. if that makes a difference.
The truck.
[IMG]IMAG0862 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0860 by jarrod vanwinkle, on Flickr[/IMG]
jarrodblake is offline   Reply With Quote
Old 09-18-2017, 02:33 PM   #2
In The Ten Ring
Re: Manual transmission thoughts for HD car hauler.
I cannot help you but I wish to commend your decision to keep the manual transmission. I wish more drivers liked stick like I do.
TTT
In The Ten Ring is offline   Reply With Quote
Old 09-18-2017, 04:09 PM   #3
B. W.
B. W.'s Avatar
You should do fine with the NV4500, the 5th gear issue is mainly with diesel trucks. There is some good reading on Quad4x4.com covering the problem & various fixes / attempted fixes.
One other option is to keep the 465 & install a Ranger gear splitter. It's basically an overdrive that fits between the trans & the bell housing but it allows you to shift into overdrive in any gear. Advance Adapters makes/sells them.
3rd option, there was an overdrive 5 speed available in the medium duty trucks that will bolt in. I can't remember the name/number, I'm sure someone here does. The problem is they are hard to find.
(HO455 beat me to it!)
B. W. is offline   Reply With Quote
Old 09-18-2017, 08:29 PM   #4
jarrodblake
I cannot stand to drive an auto, they really get under my skin when the don't shift when I want/ need them to.
TTT
Here is a link that may help you with your decision. Another option is a gear splinter like the Ranger from Advance Adapters. Let us know what you decide on.
https://www.novak-adapt.com/knowledg...ssions/manual/
The ranger gear splitter would be nice to have in a jeep or any 4x4. but for the price I would be better off with the nv4500 in the truck.
I know it's mainly caused by the vibrations of the diesels but I have read a few threads where the bigger gas trucks have has the same issues. I'm not really looking to buy it for the over drive just a better shifting transmission that is just as strong as the sm465 the OD is just a bonus. but if it was not going to hold up I was not going to buy it. As for the medium duty transmission I assume your thinking of the nv3500? I had one in a jeep rock crawler I built with the 5.9 magnum I loved that transmission and its the main reason I want the nv4500.
That said it looks like I am going to pick one up tomorrow afternoon. It comes with the bell housing, master cylinder, slave, flywheel, pressure plate, and clutch disc. I will definitely be upgrading the clutch. The transmission is a 95 I assume the flywheel will not fit the older 350? I have not decided if I want to convert it to the hydraulic clutch or not.
Old 09-18-2017, 09:00 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Here is how I replaced the SM465 in my '72 C-30 with the Chevy NV4500 on the cheap. I pull my H&H 20' tilt bed trailer with it regularly. I have hauled '99 Camaro's to '39 "A" John Deere tractors and use the OD on all but the steepest hills.
http://67-72chevytrucks.com/vboard/s...d.php?t=673588
LockDoc
Leon
Old 09-19-2017, 10:22 AM   #6
B. W.
B. W.'s Avatar
No, it not the NV3500, that's too new & lighter duty than the 4500. the 5 speed I'm talking about was produced the same time as our trucks (60's & 70's) I believe it was a Clark? Not sure, came in the C-60's.
You will like your 4500 when you get it in! You're right, the 95 flywheel wont fit your engine (1 piece vs 2 piece rear main seal)
Old 09-18-2017, 04:04 PM   #7
HO455
HO455's Avatar
RIP Bob Parks.
Old 09-19-2017, 06:26 PM   #8
mike16
x2 0n the 4500
mike16 is offline   Reply With Quote
Old 09-20-2017, 07:24 AM   #9
Andy4639
Old member
Andy4639's Avatar
Talking Re: Manual transmission thoughts for HD car hauler.
I have the 67 ramp truck with 4 speed. I'm planning on a auto when I swap it out. I want a 4l80E are something to that effect. The 4 speed is fine but I just like the auto's.
Nice ramp by the way sir!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
