Rear End Clearance
What is the minimum clearance you can have between the frame and top of rear end on a 68 C10? I have about 3" now and want to lower it another 1-1/2". Do I need to go ahead and do a C notch kit?
![]() Join Date: Jul 2015
Re: Rear End Clearance
I'd say yes, because if you haul anything with any weight you'll be out of travel and be bottoming out .
I flipped the leaf spring rear in my 69 and it dropped it just over 7". I have about 1 1/2" between axle housing and frame. I put the 3/8" thick urethane "pad" on the frame above the housing and I removed the factory bump stop steel pads on the housing.
I have no problem loading several hundred pounds in the bed, but it does hit the bump stops on big bumps.
Thanks for information. I'm gonna have about the same amount of clearance. Where did you get the pads for the frame?
They came with the DJM kit. They are a urethane puck with a 1/4" stud on the back.
