Old 09-21-2017, 08:28 AM   #1
RADustin
Rectangular Sheet Metal Weld Nuts
I lost one of the weld nuts on my front bed panel, and I noticed the same ones are used throughout the truck. I think I'm missing one on the core support as well.
Does anyone have a source to purchase these or will a home brew effort be necessary?
I'm kind of a stickler when it comes to the body of my project '76, so I'd like to make it as OE as possible. I have a spot welder to weld them back on with if I can find some.
TIA.
RADustin is offline   Reply With Quote
Old 09-21-2017, 08:32 AM   #2
MP&C
MP&C's Avatar
Re: Rectangular Sheet Metal Weld Nuts
McMasterCarr, look up weld nuts
Robert
MP&C is offline   Reply With Quote
Old 09-21-2017, 09:04 AM   #3
RADustin
Im aware of mcmaster. I guess I was looking for the factory pieces- if anyone repopped them.
They are just a simple stamped block of steel with a threaded hole. no floating nut or anything special.
Old 09-21-2017, 10:21 AM   #4
Dads79GMC
Dads79GMC's Avatar
If you have the correct tools, could be pretty easy to buy a 1/2" x 1/8-3/16" x "X" piece of steel, drill the correct diameter holes, then tap in threads then cut your squares and weld them in place????
Thanks Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 09-21-2017, 10:51 AM   #5
Dads79GMC
Dads79GMC's Avatar
Here's an example of what I'm talking about. Squares a little larger than required, but you get the idea. Best of luck!!!
Mike
Old 09-21-2017, 10:53 AM   #6
RADustin
that's going to be my go to if I can't find the exact copies of stock.
Old 09-21-2017, 11:55 AM   #7
TKCR
TKCR's Avatar
Try clipsandfasteners.com I know I have seen these somewhere.
We have **** tons of these, where I work (auto factory), but all of our stuff is metric.
Old 09-21-2017, 12:11 PM   #8
TKCR
TKCR's Avatar
It was Fastenal. They have them
Old 09-21-2017, 12:47 PM   #9
Keith Seymore
Keith Seymore's Avatar
These look factory to me (these are what I recall the weld nuts on the inside of the front fenders look like)
https://www.mcmaster.com/#=19hcobu
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-21-2017, 07:19 PM   #10
70K10Hunter
70K10Hunter's Avatar
maybe your best bet would be a donor panel and cut them off. Or do like DADS said and make your own.
70K10Hunter is offline   Reply With Quote
Old 09-22-2017, 08:23 AM   #11
RADustin
Thanks guys.
I think I'll end up making my own. I know of two that I'm missing. One on the core support and one on the front bed panel.
