Help identifying front, 6 lug disk, brake setup
Working on a 69 C10 that has 6 lug front disk brakes and I need to ID this setup? I don't know if the previous owner sourced later model parts or if they are aftermarket. I need to replace the rotors, wheel brgs, calipers etc. I'm installing a power rack and pinion setup from CPP and refreshing all front braking components.
Re: Help identifying front, 6 lug disk, brake setup
I think if you can figure out what spindles you have, you're headed in the right direction.Are they drop or aftermarket spindles with any company info on them? If so, I would guess that they are from an aftermarket 6 lug kit designed to fit the balljoints/tierod ends of your truck. Otherwise, your balljoints/tierods would have had to be changed to fit a later model spindle/disk setup.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
GM Addicted
Take rotor off. Some companies have the casting info on front of spindles.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
They could be the stock rotors.
OK, thanks for the replies guys. I pulled the rotors off and looks like they're McGaughys 2.5" drop spindles. Called them and they told me I could get all the parts at my local parts supplier, not. Finally just ordered an entire kit from Summitt.
