09-28-2017, 10:35 AM | #1 |
Active Member
Hissing from brake booster
I have a 71 k15 that while running has a hiss from the brake booster? unless my foot is on the brake pedal. Brake pedal pressure seems fine. Is this something that I should be concerned with or perhaps the start of a problem?
Any advice on what I should check? |
09-28-2017, 10:51 AM | #2 |
Re: Hissing from brake booster
Change the booster, cracked diaphram. Will lean out the engine and eventually fail
09-28-2017, 05:27 PM | #3 |
Moderator
kwmech is spot on...change out the booster before it fails on ya...
09-29-2017, 10:48 AM | #4 |
Active Member
10-4 Thanks for the help
