Just had new camshaft installed
Well I just had a new camshaft installed on my 1972 GMC. What a difference it has made. Like driving a whole new truck.
1972 GMC Super Custom Highlander |
Re: Just had new camshaft installed
So.... what cam did you install?
Yes. More info. What cam. What engine. Any other improvements on the engine
I'm looking to do this over the winter wth new heads also Posted via Mobile Device |
Subbed
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Sorry guys, not Mike the Mechanic here. Had everything done at my local shop. Here is a list of what was done to the truck. Truck also has a 350 with 91000 miles on it. Fuel pump gasket, hydraulic camshaft, manifold said, Lifter, timing chain set, timing cover set, valve cover gaskets, choke thermostat, PCV valve.
1972 GMC Super Custom Highlander Last edited by 3 4EVER; 10-04-2017 at 10:43 PM. |
So what felt new? More torque, HP, sound, response?
For starters, the truck doesn't feel like it wants to die every time you sitting at a red light. I always had to put it in neutral when I was in that situation. That is the biggest change that I have noticed so far.
