Old 10-02-2017, 01:38 PM   #1
85/Silverado
85/Silverado's Avatar
MSD Ignition rusted
My MSD Ignition Cover is all rusty inside after 2 years of use. Does anyone know why this would happen? I bought the whole MSD setup for my motor (383 Stroker) and it was installed by the builder 2 years ago, the truck has never been driven in the rain, I do wash it but so does everyone.
It stays in the garage but I do live in a very humid area. The builder just called and said I should replace the whole distributor $175 plus labor.
I'm sick to my stomach.....
Any Ideas?
85/Silverado is offline   Reply With Quote
Old 10-03-2017, 07:18 AM   #2
homemade87
Re: MSD Ignition rusted
I am no engineer but I can tell you this can be a problem around high voltage ignitions . High voltage ionizes the air and creates ozone . Ozone is very corrosive to metals and will rust out anything metal around it . The ozone is the product of the high voltage msd .
One way to combat it it to drill some holes in the cap to vent it . This is a common thing that some do to combat it in the performance world . You can buy caps that already have holes and screens . The ones with screen are mostly used in the marine world .
In the end if you put a new one in it could do the same thing . If it were mine I would clean it up and drill some holes and see how it goes . Just google it and you will most likely find lot of info on it .
homemade87 is offline   Reply With Quote
Old 10-03-2017, 07:31 AM   #3
Tiger Joe
mine is the same way. talked to MSD its completely normal and has no effect on the ignition
Tiger Joe is offline   Reply With Quote
Old 10-03-2017, 08:27 AM   #4
85/Silverado
I couldn't get it to start is why I took it to the builder. I have other motors without MSD and they don't do this.
Old 10-03-2017, 01:24 PM   #5
Tiger Joe
I can't speak to your specific situation, but I can tell you that when I spoke to MSD about a different issue, I questioned them about my concern over my distributor being very rusty inside the cap. my truck is same as you, I don't drive it in rain and I never washed my motor. they said it was normal for rust to form and wouldn't affect function
also- why are you not running a vacuum advance?
Old 10-03-2017, 02:29 PM   #6
Dead Parrot
Pick one of the brands on your other motors and install that. Looks like in your environment, the MSD model doesn't hold up. Go with something that is proven to last in your area.
Dead Parrot is offline   Reply With Quote
Old 10-03-2017, 04:13 PM   #7
85/Silverado
I just bought a HEI setup and its being installed now, I hope that fixes the problem.
The cap was arcing across the contacts and it was missing and backfiring.
Vacuum advance?
Old 10-04-2017, 04:27 PM   #8
LT7A
My folks' did the same thing. When the shop contacted MSD they said they had a vented cap for wetter climates and they got that and put it in. No problems since then that I'm aware of. Sounds like you are already taking steps. FWIW, I'm in complete agreement with homemade87's no-cost/little-labor post above.
Old 10-04-2017, 07:32 PM   #9
Tiger Joe
Yes a vacuum advance on the distributor. That distributor you posted a pic of does not have one. Does the new HEI setup have one?
It adds timing under part throttle conditions to improve drivablility.
Old 10-04-2017, 09:44 PM   #10
85/Silverado
I bought a MSD 6AL ignition controller, and MSD 85551 Distributor (pictured) and MSD Blaster 2 coil. To run the Ignition. I didn't build the engine but payed too much for sure.
