61 C-10 windshield install difficulties
I went to install the original windshield back in my 61 and I spent several hours trying to get the rubber gasket on the windshield with no success.
I don't want to break the glass but I can not get the rubber spread enough to go over the glass. I have put these type in on my previous 56 truck and 55 car. I bought a classic industries gasket which reads precision on it. Has anyone had similar problems? Do I need a better quality gasket i.e. Steele? $100 Is there a tip or trick someone could share with me? ![]() |
Moderator
![]() Join Date: Dec 2012
Re: 61 C-10 windshield install difficulties
What's the Precision part number you're using? Precision is very good, btw. I'm wondering if you're trying to use a 64-66 on it instead of a knee knocker.
I don't have the # handy but it looks long enough for the wraparound, my problem is spreading the groove or slot enough to go over the edge of the glass, its very stiff.
I set it out in the sun, warmed with a heat gun, cut down two putty spreaders and put them on each side of the glass with them in the groove and tried to slide the rubber on to the glass with no success, there is no way the corners will survive the amount of pressure I put on the flat sides. |
i had that problem with one for a '61 Corsair station wagon. No WAY it was going on.
Called them, had the correct part number, correct markings on the rubber... it was the right one. Sent it back, they sent me a new one--same part number, same markings on the rubber, same look, same corners, and it practically jumped out of the package and wrapped itself around the edge of the windshield. They couldn't explain it, and neither can I. I wonder if the cooling rate of the rubber might sometimes affect the fit or shrinkage. I dunno. But two "identical" gaskets from the same manufacturer, and one wasn't going on, the other fit perfect. You might be dealing with the same thing here. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
I had no problems with the Precision gasket in my 63. Local glass shop with an old school brother installed my windshield in 30 minutes.
I suspect something is not correct with your gasket.
292 + TKO500 |
Moderator
![]() ![]() Join Date: Aug 2011
Here are a couple of how to videos on the subject with some tips:
https://www.youtube.com/watch?v=zA8sX1KR6J0 https://www.youtube.com/watch?v=LsSB4Kad4qA
![]() Join Date: May 2011
Buy a seal from Steele Rubber. The cheap imported crap is worthless.
1960 Chevy Apache10 Short Fleetside 1961 Chevy Apache10 Short Fleetside 1961 Chevy Apache20 Fleetside 1963 Chevy C10 Short Fleetside 1965 Chevy C10 Short Stepside 1965 Chevy C10 Long Fleetside 1966 GMC 1000 Long Fleetside 1966 Chevy C10 Short Fleetside |
Mind me asking what it cost to have somebody install it? I'm about ready to have mine put in and just want to make sure I'm in the ballpark price wise.
$250
Where my garage is fairly remote, hard to find anyone to come that far out. |
Thanks! I found a place that came highly recommend today that's going to do mine next week for $267 parts and labor at my place. Lifetime warranty on seal and labor. Seems like a decent deal!
60-66 Nut
So a new '60-'63 windshield with new rubber installed for $267?
60-66 Nut
The '64-'66 windshields are much cheaper than the '60-'63 windshields. That's why I was questioning your price since this thread is about the '60-'63 windshields.
#15 |
No idea what brand mine is, but it went on really easily. It leaks like fu*king crazy. It's so loose I can lift it away from the glass with my fingers. I can also manipulate it a little up/down. Glass guy provided the glass and seal. I'm wanting to get it redone, waste of $250.
#16 | |
I will be going with precision on the next go around. |
#17 |
a couple of yrs ago my 61 was around $170 plus install. Total was $263.00. windshields are suppose to be sealed with a sealer, not just the rubber.
1961 chevy K10 my build is------------61K10 build |
