10-03-2017, 07:40 PM | #1 |
Electrical
71 350 longhorn,
new alternator, new battery, new starter, new ignition switch, new HEI dist. Won't fire, tried everything.....HELP!!! Had a battery explode, since then it's been a nightmare.! |
10-03-2017, 07:52 PM | #2 |
Re: Electrical
...will it turn over?
Have you checked 7 times to make sure that your (new) HEI distributor is timed correctly to fire for #1 at TDC. A lot of installs get this wrong or out by 180°. The best way is to check it on the damper, remove the valve cover to view the valve/spring position and then check it in the cylinder with the plug removed. If that is ok....is your HEI actually firing off a spark? All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
10-03-2017, 08:10 PM | #3 | |
Moderator
Re: Electrical
But I do know what you mean...not first time its bitten me... |
10-03-2017, 08:08 PM | #4 |
Moderator
Re: Electrical
Battery explosion...WOW!
Did you figure out what caused it? Ok...back to basics... 1/ Ign on, do you have 12 V on HEI + connection? Supply wire from Ign switch must be 12 G or larger...make sure you havent connected Ign to Tach terminal on HEI connector... 2/ New HEI distributor...does it have the module in it and is it wired correctly? 3/ Missing rotor button? 4/ Distributor timed correctly? Bring cyl #1 to TDC on compression, remove the cap and make sure rotor is pointing to #1 cyl...firing order clockwise, 18436572......see pic... 5/ Does the starter spin the engine over? Usual suspects... fuel supply ok? does the rotor spin when engine cranks over? |
10-03-2017, 10:10 PM | #5 |
Re: Electrical
You need to get a voltmeter and describe the problem with more than won't fire.
10-03-2017, 11:11 PM | #6 |
Who Changed This?
Re: Electrical
Battery explosions are usually due to loose terminals sparking during cranking. OR you could be like a guy I used to work for that would hook a 12V battery up to jump start a tractor with a 6V system. Fortunately the big chunks missed me, and I got the acid rinsed off before I went blind. Lots of crazy running loose in the world.
Please provide us with some pictures. They may help in the diagnosis.
10-04-2017, 04:02 PM | #7 |
Re: Electrical
Drop a Q and run.
Did the truck have HEI before? If no, you need to run a new wire from the fuse block to the HEI.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
10-04-2017, 04:37 PM | #8 | |
Re: Electrical
How many volts do you have at the HEI right now with the main power wire? If you are using the original, tiny little yellow power (+) wire...you might have 8 volts or less arriving at your HEI unit and this isn't going to cut it. Check this voltage....and post up the number. All Good Coley
10-04-2017, 05:12 PM | #9 |
Re: Electrical
Anytime working with a battery, SAFETY GLASSES/FACE SHIELD.
