Old 10-04-2017, 01:01 PM   #1
msg
66 c10 sound system advice?
Ive tried asking in the audio section and not had much luck so I figure since I am looking for 66 specific maybe some of you guys can give some advice.
There hasnt been a working stereo in my truck since I bought her in 96. I have been restoring her for a few years now and I would like to keep her original looking but with the modern bells and whistles. Currently the truck is dismantled and will need a new wiring harness.There is no sound system at all. The snooping I have done so far lead me to Custom AutoSound, RetroSound, and found a guy in Tennessee that takes a core unit and converts to AM/FM stereo/Aux input/USB port/Blue-Tooth with Voice Command, Aux/USB cables, 8GB thumb drive, Mic, Warranty, for 645.00 + the core and shipping.
I was hoping as most would, not to get carried away and get a nice looking and sounding system going and the bluetooth would be great but not a must. The cab I also wanted to not modify meaning keeping the doors and kick panels stock but under the bench and out of view I think is where I would try to add the rest of the sound system. Anyone been down this road and had some success?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 10-04-2017, 02:50 PM   #2
damnyankee36
damnyankee36's Avatar
Re: 66 c10 sound system advice?
Mine is still a work in progress, but here's my plan:
I found a manufacturer of repo head units that look like the factory unit but with modern internals for about $550. http://www.classiccarstereos.com/196...uck-radio.html
For speakers I grafted in some speaker grilles in the dash and rear cab corners. The pattern is modeled after the pattern of the dash center speaker. They will accept 4" x6" speakers.
Finally, I plan to install a simple compact powered sub under the seat to help with the lows that will be lacking with the 4 x 6's. http://www.classiccarstereos.com/sel...ubwoofers.html
I had the luxury of a water jet to cut out the grills. They were time consuming to weld in but in the end they look factory. I also used a sheet metal slip roller to match the contours of the dash and cab corners. I did all this to get the same result as you are looking for; a modern system that looks factory and hidden at the same time. Time will tell how well it works. Not a killer system but should sound decent.
Soon as I get home I will upload some pics.
damnyankee36 is offline   Reply With Quote
Old 10-04-2017, 04:21 PM   #3
otterscope
Once I got the interior the way I wanted, I didn't want to cut into the dash, door, etc.. I decided to get a good bluetooth speaker and connect with phone. A simple center console to hold it and best of all, I can take it out when I want to.
otterscope is offline   Reply With Quote
Old 10-04-2017, 06:52 PM   #4
damnyankee36
Here's what I've done so far...
Old 10-04-2017, 08:00 PM   #5
msg
Like that it can be easy to move in/out Otterscope, pretty cool.
Damnyankee36! Thats going many an extra mile,nice work! Ill look into the repro radios a bit more, but I might try simplifying.I dont usually listen to the radio so having an AM/FM conversion I could probably do without. As long as I can come up with a clean way to get my phone or ipod to sync up via bluetooth to a decent sound system thats all I need. I will be cutting into the dash to install the stock looking AC vents but was trying to not do more than that.
Old 10-04-2017, 08:11 PM   #6
rustbucket66
I had a guy take my original radio and put the new stuff in like you described. I like having the stock looking dash, and the radio has all the nice functions. I keep my ipod in the ash tray with the plug hooked to it. I just have the ipod hanging out of the ash tray when I am using it. I built this thing behind the seat out of fibreglass. It holds the speakers and gives some storage too. The knob to open the door is a choke cable knob like the dash has.
rustbucket66 is offline   Reply With Quote
Old 10-04-2017, 08:13 PM   #7
spacedebris
I personally like the looks of the custom autosound. The nice thing is that it LOOKS like the OE radio and will fit the dash without cutting, but has all the modern features. Also I just watched an episode of My Classic Car and the guy from CAS said that they now have a blu tooth system "Add on" that will work with all their current radios. Now unfortunately they dont have the slidebar option for the pre 67 models yet but their current versions are very nice. I also like the fact that you can start with the base unit and add options as you go so you dont have to jump into the deep end all at once. You can start with the radio and add in amps, extra speakers, blu tooth, etc. later. And for the most part they are reasonably priced.
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue.
http://67-72chevytrucks.com/vboard/s...d.php?t=523009
spacedebris is offline   Reply With Quote
Old 10-04-2017, 08:49 PM   #8
damnyankee36
Yeah, it's a little over the top. I like a challenge now and then.
Have you thought of the two speaker systems that go in place of the factory dash speaker? I also saw a post a while back with speakers in the cab corners except behind the seat. You have to fabricate a plate to mount them. Pretty much a free air system. I think I would make an enclosure of some type.
Old 10-04-2017, 08:14 PM   #9
The Rocknrod
Moderator
The Rocknrod's Avatar
rustbucket66 - Now there's something you could sell.
Old 10-04-2017, 08:22 PM   #10
Indian113
Indian113's Avatar
With the changes I am doing to my 64 and the PO putting a Kenwood Stereo in it already looking Original isn't too high on my list. I think if you are building it as Stock as you can putting in a Auto Sound would be neat. I haven't been around very many but the one I heard didn't do that good of a job. It may have been the Installer though.
Indian113 is offline   Reply With Quote
Old 10-06-2017, 07:50 PM   #11
racecougar
racecougar's Avatar
Just went through this selection process myself. I went with the Retrosound Long Beach, and I'm extremely happy with it.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 10-06-2017, 08:37 PM   #12
rvrfoot
I just upgraded.Name:  DSCN0987.jpg
rvrfoot is offline   Reply With Quote
