10-04-2017, 06:42 PM | #1 |
New Bed Wood time.
Finally got around to replacing the bed wood. Judging from the half dozen holes and the mushroom farm underneath, it's time..
10-04-2017, 06:48 PM | #2 |
Re: New Bed Wood time.
Here's a pic of the new wood. Still have to sand it, drill the hole, stain it, and then preserve it. Shout out to GMC Pauls for the graphic on the measurements.
Still have a bit of work ahead of me. |
10-04-2017, 08:44 PM | #3 |
Nice. I'll be watching.
10-05-2017, 06:56 PM | #4 |
What type of wood are you using?
1967 Chevy Truck 1969 Chevy Panel Truck work in progress 1971 GMC 1500 all orginal 1972 Chevy Suburban brought from orignal owner 1984 Dodge Rampage 45,000 original miles 1992 Dodge D150 1994 Buick Roadmaster (LT1 Engine) 2000 Chevy Stepside Z71 2008 Honda Element |
10-05-2017, 07:54 PM | #5 |
It's "Arkansa Pine". I has a real nice grain pattern to it, and it doesn't have any knots or splits. The lumber yard I bought it from was real good about me being able to pick my boards, and then I cut them to length fight there.
The only down side, if there is one, is that I had to buy 16 foot long boards, in order to get the 97 inch length (why couldn't it have been 96, but that would've been too easy), so I have a bit of lumber left over. That's ok though, because I have lots of projects to use it on. |
10-05-2017, 10:56 PM | #6 | |
1968 LWB C20 / AC / Wood Bed |
10-05-2017, 11:24 PM | #7 |
I'm always interested to see how the different grains turn out. I just finished pine as well, so yell with Any questions, and good luck on the project!
Jim |
10-04-2017, 10:19 PM | #8 |
I just picked up some tigerwood today for my bed -- looks great but I got 3/4" and I'm worried that it might be too flexible. How thick is your wood?
10-04-2017, 10:33 PM | #9 |
Recently re did mine. Would've been easier with bed off the truck but it wasn't to bad doing it with it on. Good luck.
10-04-2017, 10:41 PM | #10 |
1972 GMC Super Custom Highlander |
10-05-2017, 10:29 AM | #11 | |
I had o ct the short outside boards to width, but the long boards were spot on. 3/4 thick is what the factory used so your boards should be fine. |
10-05-2017, 10:38 AM | #12 |
Found mine in a wrecking yard 20+ yrs. ago. Stored it complete on its side until recently when having my truck reworked. It was originally a long bed but was cut down to fit. Has some aging to it naturally but just gives it character like the character that will be behind the wheel.
Smitty '71 Short Fleetside Spring Valley, Ca. |
10-08-2017, 03:41 PM | #13 | |
Moderator
post pics for us... |
10-08-2017, 10:49 PM | #14 |
Yup, you need a good set of woodworking tools. If it's dimensional lumber you won't need a planer or joiner, but you will need a table saw with dado blade set.
It also helps to have an assistant to help feed the board through the saw. After that I measured and made templates for the counter sunk washers. As I said it takes a few woodworking tools that would be cost inhibitive for one time use. The reason I cut my own is that I already have all the tools. |
10-08-2017, 10:52 PM | #15 |
My carbide miter saw blade and router bits didn't seem to have any problem at all with this stuff, it's hardness is in between oak and ipe I believe. I did finish the area around the tubs but didn't get any pics, I'll have to post those up later
10-06-2017, 09:33 PM | #16 |
I'm staining, I am not a fan of stripping failing coatings! I'm going to use Armstrong Clark Hardwood Transparent, just not sure whether to go mahogany or amber yet...
1968 LWB C20 / AC / Wood Bed Last edited by crakarjax; 10-06-2017 at 10:08 PM. |
10-07-2017, 12:35 AM | #17 |
I used a pine kit. Burned the grain and gave it 3 coats of semi gloss spar urethane. Painted the bottom and sides with rustoleum high heat bbq paint.
10-07-2017, 08:48 AM | #18 |
Now that' a different approach. Really sets it off too. I take it that you just went over it lightly with a small propane torch, then sanded it? I like it.
10-07-2017, 09:36 PM | #19 |
Yeah that grain looks really cool singed! I'm using this end sealer on my boards
http://amzn.to/2ywRIt5 And I heard this stuff is the best for oiling, it's made for hardwood and penetrates without creating a hardened film on the surface -- formulated for really dense hardwoods with interesting resinous properties: http://amzn.to/2z5jEl1
10-07-2017, 11:40 PM | #20 |
The new beds that are shown are awesome! I do like the fired look but I don't have a torch big enough for the job.
Any suggestions on where to start installing the new wood? Outsides, working back and forth, with the two thinner boards last is what I'm going to do. Am I right? |
10-08-2017, 10:45 AM | #21 |
Yup, that is the approach I used also. For the last strip or two, you will need a helper on the opposite side, or use something heavy to hold the carriage bolts down while you get the nuts started. Anxious to see it installed!
Jim |
10-09-2017, 08:44 PM | #22 |
Here's a pic of all the wood set on the sills
10-09-2017, 10:02 PM | #23 |
Are you not using wear bar strips ? Looks like all your boards are the same width, beautiful none the less
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
10-09-2017, 10:41 PM | #24 |
Thanks! No strips, just 5.5" boards all the way across. If I need to haul something I'll probably just throw an old rug on top of it. I'm going to fasten the boards from underneath with stainless sheet metal screws, although some are going to require creativity to get to...
