Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-09-2017, 07:38 PM   #1
Gromit
Glovebox Toolkit - Cheap
Thought I'd share this socket to wrench adaptor I found at HF for a couple bucks.. lets you just use a 9/16ths box end wrench with a full set of sockets for a cheap and compact toolkit you can carry around and it won't be a disaster if someone steals the whole kit. It doesn't ratchet of course but this is only for emergency repairs.
With this and a cheap set of wrenches and sockets and two convertible screwdrivers and a socket extension hopefully can fix a few things on the road without carrying too much.
The carabiner wasn't my idea but it makes a good wrench holder/organizer.
Gromit is offline   Reply With Quote
Old 10-09-2017, 07:45 PM   #2
notsolo
notsolo's Avatar
Re: Glovebox Toolkit - Cheap
Brilliant, you need a small pouch and your good to go.
notsolo is offline   Reply With Quote
Old 10-09-2017, 07:46 PM   #3
flashed
Why not add a small ratchet ?
flashed is offline   Reply With Quote
Old 10-09-2017, 08:15 PM   #4
In The Ten Ring
I have come to the conclusion that nothing short of building my own bed tool box will suffice.
1). 3/8 inch socket set
2). 1/4 inch socket set
3). ratcheting wrench set
4). screwdrivers
5). pliers/channel locks/needle nose
6). telescoping magnet
7). jumper cables
8). wiring repair kit
9). water
10). 2 quarts oil
11). road flares/reflecting triangle
12). hi viz vest
13). jack
14). tire plug kit
15). tow strap
16). cheater bar
17). tire iron
18). STG 44 with 500 rounds
19). panzerfaust
LOL. See what I mean?
Do you know what's even more crazy? I carry items 1 - 17 plus crow bar, axe, and rugs in my car trunk.
In The Ten Ring is offline   Reply With Quote
Old 10-09-2017, 09:32 PM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
4). screwdrivers
7). jumper cables
9). water
10). 2 quarts oil
12). hi viz vest
13). jack
14). tire plug kit
15). tow strap
16). cheater bar
17). tire iron
19). panzerfaust
Ten Ring: What no E-Tool? 50 pushups!
Old 10-10-2017, 07:34 AM   #6
My first thought. I'd loose that and be s.o.l. anyway. And tools, or anything heavy, don't go in my cardboard glovebox. But I get the term is being used in a generic way
Old 10-09-2017, 08:38 PM   #7
flashed
I carry way to much .
Old 10-09-2017, 08:50 PM   #8
Drew3
I personally would prefer a panzerschreck for the occasional wild T-34.
Drew3 is offline   Reply With Quote
Old 10-11-2017, 01:38 PM   #9
mrein3
mrein3's Avatar
Ich habe keine panzerschreck.
On a serious note, I'm always amazed what I can fix roadside with a neat little wrench I picked up along the way somewhere. It is a box end wrench with 9/16ths on one end and 1/2 on the other.
When I was younger my "Chevelle kit" included the above wrench, most recently replaced upper and lower radiator hoses, a 50/50 gallon of antifreeze, the most recently replaced fan belts, a 6-way screwdriver, and a dime to call home.
Yes that was before cell phones and credit cards.
My WWII veteran neighbor when I was growing up said with his model T all you needed was a spare tire, extra transmission bands, and a wire cutter. As long as you followed a fence line you could fix anything but the transmission and a tire with a hunk of wire.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-11-2017, 07:23 PM   #10
In The Ten Ring
The panzerschreck is a good weapon but it does best with a crew of two and takes up more space. Of all the battles I saw with Gross Deutschland Division on the Ost Front, I never once saw a panzerschreck. SMH.
I forgot to list:
water
funnel
duct tape
black tape
plastic bags
poncho
2 screw jacks in summer and in winter, both of those plus a hydraulic jack and tire chains
first aid kit
5 pound CO2 extinguisher
small ABC extinguisher....... geeze.....I need a utility bed!
Old 10-09-2017, 09:10 PM   #11
'68OrangeSunshine
I carried #19 + 20 on my '61 MBz190. When that blew an engine [long story] and I bought a '68 Chevy truck, it came w/ M3 Greasegun and 2.5'' bazooka. Just as effective but easier to come by parts and ammo. The seller kept the M2 .50 Cal and flex-mount, that was on the back deck, but the extra $50 he wanted for it was more than I could swing at the time.
As for the OP's kit: Agree'd, Brilliant. But since we're not shedding ounces and grams for some bicycle competition, the small space and weight of a 3/8'' ratchet justifies its addition. Nice trick with the 9/16 -- all the same.
Now, if your 9/16 Combo wrench was a GearWrench, with selectable ratchetting on the Box end, you'd have the best of both worlds.
Old 10-09-2017, 10:05 PM   #12
mike16
what? no hammer?
mike16 is offline   Reply With Quote
Old 10-09-2017, 10:15 PM   #13
Leonard60
What happens if you need a socket and a 9/16 wrench at the same time??
Leonard60 is offline   Reply With Quote
Old 10-09-2017, 10:33 PM   #14
'68OrangeSunshine
Originally Posted by mike16 View Post
what? no hammer?
He uses the buttstock of his StG44.
Old 10-09-2017, 11:53 PM   #15
Gromit
You got me there! It certainly isn't the cost as HF sells them way cheap - I was just trying to reduce the kit to the absolute bare minimum.. My Brother-in-Law gives me grief even for carrying this much - according to him all I need is a Visa Card and a cell phone.
Aha! you are thinking ahead! If you look at the carabineer in the photo you'll see there is one wrench not part of the original set - that is an extra 9/16ths to hold the sockets in case needed to keep a bolt from spinning.. So in other words there are two 9/16ths in this kit. I should have mentioned that and good question.
Old 10-10-2017, 12:57 AM   #16
Killer Bee
Killer Bee's Avatar
toolkit? did I click on a Ford site by mistake??
Killer Bee is online now   Reply With Quote
Old 10-10-2017, 01:04 AM   #17
jjzepplin
jjzepplin's Avatar
Now that shiz is funny!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-10-2017, 06:49 AM   #18
custom10nut
custom10nut's Avatar
I've l always carried a small tool kit in every vehicle I own, BUUUUT haven't had to use any of them on my own vehicles.
I've been the "Good Samaritan" for more people than I can count.
How many times have you been at the parts store, or Home Improvement store, or the Rest Stop and felt compelled to help someone?
custom10nut is offline   Reply With Quote
Old 10-10-2017, 07:38 AM   #19
Is your brother-in-law a woman, not much of a man, or just has a weird thing for preferring to be helpless?
Old 10-10-2017, 07:48 AM   #20
muley
muley's Avatar
... and a can opener
for the brother in law
Grandpa 1953 M38A1 Jeep
1989 GMC K2500
1958 Alaskan Camper all original
WORK : A necessary evil that finances
what I really like to do.
muley is offline   Reply With Quote
Old 10-10-2017, 06:52 AM   #21
hamjet
hamjet's Avatar
Duct tape and bailing wire here...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 10-10-2017, 09:28 PM   #22
I often carry nothing but luck. I was driving the '90 Blazer I had down in VA while working on my sister's place. I was almost into town slowing for a red light and noticed I had a rear tire "loping". I pulled onto the grass to find I had only one wheel stud left w/lug nut. I had no tools except a carpentry tool bag and my son had not put the jack handle back in the truck. I had a pair of tin sheers I opened up to make a cross, stuck one tip in the jack and raised the truck. I removed the one lug nut. Now this thing had a posi so no spinning the axle with only one side lifted. Fortunately all 5 broken studs sat with nothing like the wheel cylinder in the way. I took the drift punch out of the tool pouch and knocked the busted studs out. Right about then someone stopped to offer help so I got a ride to NAPA for studs and lug nuts. Was able to get them all installed w/o spinning the axle and went on my merry way to have dinner with the gal who stopped and helped me. Figuring out how to fix it without proper tools was routine, being able to remove and replace the studs was fortunate, but the dinner date and rest of evening was pure luck!!
That's just one story of getting through a breakdown smoothly when not well equipped. Gotta have faith man
Old 10-11-2017, 08:52 PM   #23
You forgot MREs in case you left something out
Old 10-12-2017, 02:31 AM   #24
In The Ten Ring
Normally we "lived off the land" in Russia (captured local stocks) but those days are long gone now......
MRE's would not be a bad idea. Seriously!
Old 10-12-2017, 05:41 AM   #25
mongocanfly
mongocanfly's Avatar
could just swap the 9/16 box end for a 9/16 ratchet wrench...
