Old 10-12-2017, 05:42 PM   #1
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
Wiper Motor Hot to Touch
My wiper motor is hot to the touch. Im guessing somekind of internal short. Has anyone else encountered this before?
Thanks,
Ryan
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 10-12-2017, 09:29 PM   #2
HO455
HO455's Avatar
Re: Wiper Motor Hot to Touch
It could be low voltage to the motor. The voltage is easy to check. There are several threads on troubleshooting wiper motors and switches if you do a search. A bad ground can cause the voltage to be low too.
Or it could be too much resistance from the wiper arms and the bushing through the firewall. (Which I had on my Burban.) The resistance check would require removing the motor and running it disconnected from the arms to see if it runs cooler.
RIP Bob Parks.
Old 10-12-2017, 11:08 PM   #3
Bagd72Chevy
C10 Collector
Sorry, forgot to mention this was with the switch off. Motor not spinning but it was hot. Hadnt been on all day. No wiper arms installed yet.
Old 10-12-2017, 11:54 PM   #4
HO455
HO455's Avatar
That's not a good sign. Sounds like the motor is stuck out of the park position and is trying to get there. I would unplug it now! Have you removed it from the firewall? My firewall bushing was dragging so the wipers were moving at about half speed. Yours maybe worse than mine was.
Another possibility is the brushes in the motor are so worn that the motor can't turn to get back to the park position.
Here is Lockdoc's thread on wiper electrical to help you test the circuitry.
http://67-72chevytrucks.com/vboard/s...d.php?t=413551
RIP Bob Parks.
