10-14-2017, 05:35 PM | #1 |
Can I use a sb400 flexplate on a sb350
Getting ready to install my engine & trans & I have a flexplate question. I have several flexplates in my stash, however they all appear to be balanced. I say that because they have several extra drilled holes which I am assuming is for balancing.
My question is can I use 1 on the 350 engine I am installing? Seems to me that a balanced flexplate wouldn't do harm to a 350 but visa versa would be a problem (unbalanced on a 400 engine). Any input would be appreciated. We all know what happens when we assume. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
10-14-2017, 05:41 PM | #2 |
At the body shop.
Re: Can I use a sb400 flexplate on a sb350
No. External balance 400
internal balance 350. The 400 should have a large counter balance weight
" That didnt make it any newer " " Dont antique the equipment " |
10-14-2017, 06:29 PM | #3 |
Thanks 4 the input. The other flexplates I have do have counter weights, but this 1 only has the extra holes.
Here are a couple pics:
10-14-2017, 11:19 PM | #4 |
ttt
10-15-2017, 12:40 AM | #5 |
"they have several extra drilled holes which I am assuming is for balancing."
On a flex plate with weights you will actually see a chunk of metal welded on that is the weight. |
10-15-2017, 01:06 AM | #6 |
At the body shop.
I'd buy a new one that hasn't been messed with.
100-2901 bolt kit SCAT Engine Components FP-350-SFI - Scat Flexplates
10-15-2017, 06:51 AM | #7 |
I think the holes were drilled to balance the TH350 flexplate. I mean, even with an internally balanced engine you would want the flexplate fairly balanced. The TH400 ones are "counter balanced". No weights = TH350.
10-15-2017, 03:01 PM | #8 |
So, looks like I can use this 1 on a 350/350 combo?
Will probably just go buy a new 1 but would like to know incase I need it in the future. Thanks
