Old 10-25-2017, 12:18 PM   #1
demian5
demian5's Avatar
1970 Small Block AC Brackets
Can anyone post images of ALL brackets used by the factory to mount a stock ac compressor onto a small block engine in a 1970 C10?
Thank you.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 10-25-2017, 12:41 PM   #2
rsavage
rsavage's Avatar
Re: 1970 Small Block AC Brackets
I don't have access to photos since photobucket blocked third party use of my images, but if I remember correctly there are seven pieces.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-25-2017, 04:11 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 1970 Small Block AC Brackets
Here you go.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-26-2017, 12:05 PM   #4
demian5
demian5's Avatar
How does the front thick bracket bolt to the motor?
1986 C20 Scottsdale
Instagram: C10sofOC
Old 10-26-2017, 12:29 PM   #5
rsavage
rsavage's Avatar
Don't know if these will help
1961 C1 Corvette
2021 Durango RT 5.7
Old 10-26-2017, 12:39 PM   #6
demian5
demian5's Avatar
Yeah i want to see where the bracket attaches down at the water pump area. And that long pivot bracket, how do I adapt it with headers? Some thick spacers?
1986 C20 Scottsdale
Instagram: C10sofOC
Old 10-26-2017, 12:49 PM   #7
rsavage
rsavage's Avatar
Don't know how you would adapt the stock bracket with headers as one spans and fastens to the exhaust manifold bolts. You can't use the stock brackets on an aftermarket aluminum intake either in my past experience.
1961 C1 Corvette
2021 Durango RT 5.7
Old 10-26-2017, 02:02 PM   #8
demian5
demian5's Avatar
Wow, maybe I just go with a sanden aftermarket compressor and brackets.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 10-26-2017, 04:18 PM   #9
Andy4639
Old member
Andy4639's Avatar
That would be easier. I had to when I swapped mine. Classic air has a kit and that's what I bought.
Old 10-27-2017, 07:00 PM   #10
demian5
demian5's Avatar
Do I still run the POV valve and everything else??
1986 C20 Scottsdale
Instagram: C10sofOC
Old 10-27-2017, 08:37 PM   #11
Andy4639
Old member
Andy4639's Avatar
Talking Re: 1970 Small Block AC Brackets
You can buy as much are less as you want.
