10-27-2017, 10:58 AM | #1 |
Installing a C-Notch on C10 PU
For the properly done drop of my C10 PU, I selected the CPP heavy duty C-Notch kit that comes with all grade 8 hardware. The frame cuts were done accurately and straight using a die grinder and then smoothing everything with rotary sander. Everything went without any problems and the CPP brackets fit beautifully. After all hardware was installed, the brackets were also welded to the frame. Finally, the frame was cleaned and painted.
I also installed a new Eaton TrueTrack posi rear and Wilwood brakes all around. The results were well worth the labor and expense.
1972 C10 SWB, 1970 Corvette, 2017 Grand Sport |
10-27-2017, 11:20 AM | #2 |
Re: Installing a C-Notch on C10 PU
Nice work, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
10-27-2017, 12:41 PM | #3 |
nice touch welding it to the frame and using the HD kit. May be stronger then stock now! Looks very slick with the paint too.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
10-27-2017, 01:10 PM | #4 |
Ekliptix: I noticed you are using the 700R4, Eaton posi, with the 3.73 which I will be using as well.
I selected the 3.73 as a mild performance ratio but hopefully would be somewhat highway friendly due to the overdrive tranny. How has the 3.73 worked out for you? If you know, about how many RPM's do you turn at 60 mph?
