10-28-2017, 01:49 AM | #1 |
Wiring Harness Question
Well after about 20 years I'm finally starting to get my Dad's 1970 GMC back together.
Does the rear wiring harness run on the drivers side or the passengers side? It been too many years to remember how I took this apart. Then 1974ish Now
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
10-28-2017, 07:09 AM | #2 |
laying low
Re: Wiring Harness Question
The rear wire harness runs down the driver side of the frame. You're going to have a real nice truck there.
10-28-2017, 08:00 AM | #3 |
Blog is correct. And I second his thoughts on your truck. Sweet ride!
10-28-2017, 08:11 AM | #4 |
Wow, Your building a Rocket Sled. Good thing you removed the camper, too much wind resistance...What did you use for a drive shaft, and who made it?
10-28-2017, 10:27 AM | #5 |
That's a problem I'm having with the RideTech suspension. I talked to RideTech before ordering and was assured it would fit a long bed. The RideTech does not have any provision to mount the center bearing for a two piece driveshaft. I had a local shop build a one piece shaft. He wasn't comfortable with the length using a 3 inch shaft and used 3.5 inch for the shaft. Now with the suspension unloaded, fully extended, the shaft hits the inside bottom of the cross member. So far RideTech hasn't been much help resolving this. Not sure how to proceed with this problem.
10-28-2017, 08:15 AM | #6 |
I have to agree with all of the above... Just an FYI... if you plan on an ABS/Tracs system, keep THESE separated from your main rear harness and run them on the right side. The reason for this is EMF (Electro-Magnetic Interference)... it also wouldn't hurt to wrap the wheel speed sensor wiring with aluminum tape.
**RED SEAL CERTIFIED JOURNEYMAN SINCE 1993** My 1966 GMC Value Van Project 1951 GMC 9430 1-Ton I'm just going to put an OUT-OF-ORDER sign on my forehead... and call it a day. |
10-28-2017, 08:41 AM | #7 |
That is going to be one sweet ride! One note on your Sanden AC compressor.
You need to rotate it up so the ports for the fittings are pointing up. The reason for that is with the ports pointing down the compressor oil will drain out of the compressor when the truck or AC is not being used and that will ruin the compressor.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
10-28-2017, 10:33 AM | #8 | |
10-28-2017, 11:34 AM | #9 |
Thanks for the reply on the drive shaft, you may have to compromise the fully unloaded with a 1" or more bump stop on the axle. Not what you wanted to hear...post a question in the suspension section, hope you get a good alternative.
10-28-2017, 01:39 PM | #10 | |
So a bump stop wouldn't really help.
10-28-2017, 10:31 AM | #11 | |
