Old 10-28-2017, 05:56 AM   #1
nevada
noticed th350 slipping
my c20 th350 recently began slipping, have only noticed slip in first and reverse. am generally happy with th350 if I stick with it and rebuild, is it possible to have final third gear changed from 1.0 to say 0.90 ? running 4.1 rear gear but planning on changing that at some point.
nevada is offline   Reply With Quote
Old 10-28-2017, 07:39 AM   #2
Re: noticed th350 slipping
Not possible. The unit is designed to run at 1:1 final drive. Not as simple as a gear change in a manual transmission. Even if you could, you would only have three gears and sacrifice 3rd.
I assume your fluid is topped off and it still slips. Does the fluid look burnt?
Old 10-28-2017, 07:55 AM   #3
Aberdare
Aberdare's Avatar
... not possible, unless you're an engineer with access to hundreds of thousands of dollars worth of... oh wait, why not just rebuild it to original specifications and be driving it sooner rather than later...
**RED SEAL CERTIFIED JOURNEYMAN SINCE 1993**
My 1966 GMC Value Van Project
1951 GMC 9430 1-Ton
I'm just going to put an OUT-OF-ORDER sign on my forehead... and call it a day.
Aberdare is offline   Reply With Quote
Old 10-29-2017, 05:28 PM   #4
Heavymetl
3rd "gear" has no reduction, the power is transmitted at a 1:1 ratio straight through to the output shaft. Overdrive transmissions have another gearset for the task.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 10-29-2017, 07:09 PM   #5
AussieinNC
Moderator
AussieinNC's Avatar
Look into putting a 200R4 into the truck...same length as a T350...has overdrive...and can be built pretty stout ,...
Just my two cents worth
AussieinNC is offline   Reply With Quote
Old 10-29-2017, 07:11 PM   #6
Bigdav160
Bigdav160's Avatar
Nothing in common with first and reverse. It would be strange to have those symptoms in common.
The gear set turns as a locked unit in third so no way to get an overdrive ratio
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
