crew cab frame shortening
Hey guys, does anyone have a link to a detailed thread how to shorten a lwb frame to short box. I have read one where its detailed on where and how to shorten it with the z cut or step method. Any help will be appreciated. Thanks
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: crew cab frame shortening
14" in front and I believe I did 3.5" in the rear.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Thanks for the info, I was really looking for an old thread that showed how you map out the z cuts, but after more searching today, I found it.
Just looked at your 72 Crew build, that is looking good. I plan on starting on one after the first of the year. Would you be willing to give some pointers then? Thanks again |
I had originally planned on the "Z" cut for mine, but after a bunch of research I went with the 45 degree cut. I read a couple places that cracks eventually formed coming off of the splice... even with rounded corners. There are so many guys out there that have done straight cuts with no issues, I am quite confident in my 45 degree transition lasting forever. I covered it pretty well in my build... link in sig.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
