Start up issue
I have a recently rebuilt 72 C10 and it sits during the week and on weekend when I go to start it, I have to pump the gas pedal and turn it over for about a minute before it finally starts up - I drive it through out the weekend and it starts on first turn. Then when I let it sit for the next week, it's hard to start and we go thru the same process again. I have a manual fuel pump on it. Is there anything I can do so it is ready to start after a week long layoff?
Thanks,
Texas - Don't Let The Size Scare You! |
Re: Start up issue
What carb?
Re: Start up issue
Rochester 4 barrel - factory carb - 350 engine - recently rebuilt carb and engine
![]() Join Date: Jan 2001
Re: Start up issue
Did you replace the filter in the carb inlet, and does it have the flowback preventer valve in it?
Also, did you set the float level according to the instructions in the rebuild kit?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Re: Start up issue
Leaking fuel plugs on bottom of carb. Common problem.
Re: Start up issue
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#7 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Start up issue
Maybe there's an issue with the flowback preventer valve and it would help if I knew what I was looking for. Any further info would be appreciated -- pic, diagram, etc. I have never heard of it before now.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: May 2016
Re: Start up issue
Is the Axcelerator pump working? When you pump it. Did you look in the carburetor and see if it was getting gas? With it not running.Sometimes they dry out. And when you get them wet again. it might work for a while.
#9 | |
Re: Start up issue
Re: Start up issue
Wow my 71 with a Q-Jet also does the same thing. Where is the best place to start troubleshooting?
-1987 GMC Sierra Classic 5.3 LS - -2001 Toyota Camry 175k - |
20' Daredevil (Ret)
Re: Start up issue
Thanks! I'll make sure it's there... if not, I'll get a new filter and make sure it has that flap. I don't recall seeing it before, though....
![]() Join Date: Jul 2016
Re: Start up issue
Fuel pump is probably leaking fuel back to tank and has to refill line and carb, how old is the fuel pump.
You can check this by removing the line and seeing how much fuel is in it. There is a check valve in the pump that when operating correct prevents drain back. |
Re: Start up issue
Is your divorced choke new too?
Did you clean out the crossover in the intake during the rebuild? |
Re: Start up issue
I believe this is just part of owning a carburated vehicle. We are all spoiled with fuel injection and all these bells and whistles. Yeah this is an issue that can be fixed, but its so common of carb vehicles that its almost like a theft deterrent!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#15 |
Re: Start up issue
You could install an electric fuel pump. It would pump fuel up to the carb before the motor turns over.
#16 |
Re: Start up issue
Had the same issue. Replaced the fuel pump, and that ended the problem.
1972 Chevrolet C-10 "Ba-Lou" |
#17 |
Re: Start up issue
I would bet the fuel plugs are leaking the bowls dry when sitting the short time. Then the fuel pump takes a bit to fill the bowls back up. If you want a quicker start, the bowl air vent tube, yes, that 1/4 inch "tube" that is slanted back towards the breathed stud, on top of the carb, you can squirt a few shots of fuel directly into the bowls. And then maybe a small squirt into front two barrels for a quicker fire up. I let too many of my old clunkers sit too long also.....
