11-07-2017, 08:55 PM | #1 |
Please Help ID Differential
Recently bought my 72 3/4 Ton 4 X 4 and want to upgrade the differential cover but don't know what differential this is. Was thinking it was a Dana 60 but the Dana 60 covers I've seen online aren't designed anything at all like the one on my truck. This cover is mostly just round whereas the Dana 60 covers online aren't round. Also, it has 8-lug axles. Appreciate any help anyone can provide.
11-07-2017, 09:02 PM | #2 |
Re: Please Help ID Differential
Eaton. Last year for that diff was 1972
You probably won't find any aftermarket support.
11-07-2017, 09:04 PM | #3 |
6>8 Plugless........
That is a HO52 more than likely. There is someone that makes an aluminum cover for it. I will see if I can find the link for it.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-07-2017, 09:07 PM | #4 |
Thank you very much guys. VERY much appreciate it. Does the Eaton have any advantages over the Dana? Very glad I found this site as everyone is very helpful.
11-07-2017, 09:22 PM | #5 | |
https://www.google.com/search?domain...D%3A1%3B&hl=en Very nice truck too by the way! I haven't found that link for the cover yet. After an edit.... I have found 2 different ones. http://www.ruffstuffspecialties.com/catalog/R1970.html http://999offroad.com/product/eaton-...ty-diff-cover/ https://www.google.com/search?q=ho52...w=1270&bih=937
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 11-07-2017 at 09:27 PM. |
11-07-2017, 10:09 PM | #6 |
Thank you very much Ryan. Appreciate the help!!!
11-07-2017, 10:47 PM | #7 |
Very nice K/20 you have. Looks like Ryan has you covered on the info you've asked. Yes, the HO52 is a very good rear. Compared to the Dana60 I'd say the HO52 is stronger.
Those mirrors are swung out for towing/camper hauling. If you're not doing any of that it's best to have them folded in. Less chance of clipping them on something and damaging your door. Heck, I find even when towing folded in works fine...unless towing something a whole lot wider than the truck. They look pretty goofy hanging way out there anyway, IMO.
11-08-2017, 01:41 PM | #8 |
Six in a row makes it go...
Thread here with another thread referenced in it:
http://67-72chevytrucks.com/vboard/s...d.php?t=747900
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
01-21-2018, 04:00 PM | #9 |
Thanks for all the help guys. As I've read the many links, it's possible that my differential may be an HO72 since it has leaf springs and is a 3/4 ton camper special. When I search for a differential cover gasket stating 72 K20 all I'm given is the HO72 gasket. Is there a visual indicator to tell if it's a 72 or 52?
1972 K20 2004 Chevy Aveo 2011 BMW X5 Diesel 2018 Chevy Silverado Diesel U.S. Air Force Retired - 1983-2017 |
01-21-2018, 04:21 PM | #10 |
20' Daredevil (Ret)
HO72 was typically on one-ton trucks... unless yours has been changed it is an HO52. Leaf springs don't matter afaik..... all K20s came with leaf springs. Cover gasket will be the same either way. HO72 has bigger brakes and possibly some bearings (axle bearings?) are bigger than HO52, but for the most part they are identical including the center section.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
01-21-2018, 04:25 PM | #11 |
Is this a mirror thread ??
Stan 67 swb BLU MULE posted via flip-fone |
01-21-2018, 08:18 PM | #12 |
The HO52 is the progenitor to the full-float 14 bolt. In stock form GM considered it good for 5200# GVW (thus the 52) while the Dana 60 was 5500# GVW.
They are very stout rear end and no need to replace it if in good condition. The HO52 can be upgraded to newer 14 bolt axles and the 14 bolt Detroit. If I had one in my truck and it was in good shape I would run it. If I was faced with rebuilding it, I'd score a full-float 14 and swap it in. Or if you want to run a limited slip instead of a locker I'd look at a 14 bolt swap or if you want less than 4.10 gears.
