Old 11-10-2017, 01:30 PM   #1
Notes
Different heights after lowering?
72 C10. 4” drop springs in rear. Shock relocate. There’s a difference of a little over 3/4” from D to P sides. No big deal, or did I screw something up? Thanks
Notes is offline   Reply With Quote
Old 11-10-2017, 06:39 PM   #2
SCOTI
SCOTI's Avatar
Re: Different heights after lowering?
It's not uncommon to have differences side to side on a 45yr old vehicle. 3/4" difference is not unheard of but is kind of excessive.
This is why I always take measurements before any work is performed. Those details help answer whether the problem was pre-existing (possibly worn body bushings or tweaked frame) vs a possible result of the install.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-10-2017, 06:46 PM   #3
rharris
rharris's Avatar
I ended up with about 1/2" difference on my 72 C. I used CPP coils and they didn't seat the best in the front. I assumed it was due to that.
72 Cheyenne Super C10 SWB
2001 Silverado 1500HD Crew
2011 Silverado 2500HD Crew Duramax (Hers)
rharris is offline   Reply With Quote
Old 11-12-2017, 09:16 PM   #4
OARNGESI
OARNGESI's Avatar
Drive it a bit and see if it settles it’s common for chevys to lean to the driver side
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 12-04-2017, 07:22 PM   #5
David12460
Weight differences from right to left can play into this, and so can control arm bushing bind. Those two things are the biggest contributors to this problem.
David12460 is offline   Reply With Quote
