Old 11-11-2017, 03:37 PM   #1
dhunt00c
lokar pedal assembly question
I have a 68 C-10 cab, firewall holes have all been filled.
I've noticed there is a different locker pedal assembly for 67-70 and 71-72.
The 71-72 seems to be a cleaner install as there is no outer plate on the firewall.
My question, is why are they built slightly different? Anyone know if its because of factor firewall holes or to correct an alignment issues with the carb?
I like to install of the 71-72, but i don't want to order it if it's going to cause me headaches. Anyone have knowledge or experience here?
Thanks in advance!
David
dhunt00c is offline   Reply With Quote
Old 11-11-2017, 04:07 PM   #2
harpo231
harpo231's Avatar
Re: lokar pedal assembly question
The mounting between the two pedals (67-70 rod) (71-72 cable) is different.
http://67-72chevytrucks.com/vboard/s...00#post1383300
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 11-12-2017, 01:36 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: lokar pedal assembly question
Correct. 71-72 is hooked up by cable to the carb.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-12-2017, 11:47 PM   #4
dhunt00c
Yes, I’m aware of that. But if my firewall has already had all holes fillled and I like the way the 71-72 polar pedal mounts, can I use it and cut the hole I need for the cable or is there some other reason such as alignment with carb that I should stick with the 67-70 version on a 68 cab?
Old 11-13-2017, 02:02 AM   #5
cr1hotrod
cr1hotrod's Avatar
I just installed one in my '67 the other day. The 71-72 pedal uses all three bolts. The 67-70 only uses 2 holes and the third(top right from seat) is is just filled with a short bolt.
Check out the instruction sheet...top page is early, bottom is later
https://checkout.speedwaymotors.com/...structions.pdf
The picture on speedway for the early (XBAG-6164) on speedway is wrong, it's the later one pictured.
I did switch mine over to a cable with the early pedal, just had to drill out the pedal arm slightly.
1967 Longbed 4/6 static
2007 Silverado Z71 Crew
cr1hotrod is offline   Reply With Quote
Old 11-13-2017, 02:08 AM   #6
cr1hotrod
cr1hotrod's Avatar
Also, On the instructions....You'll notice the big hole below where they're drilling the hole for the early pedal...That's your rear harness firewall bulkhead...The pedal arm will bottom out on the wiring there. So that's kind of crappy...lol
Old 11-13-2017, 08:28 AM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: lokar pedal assembly question
There is no reason that I know of that would keep it from working. I took mine out and used the Lokar pedal assembly.
Old 11-13-2017, 09:55 AM   #8
68Stepbed
68Stepbed's Avatar
You say your firewall has been filled, but have the mounting nuts been removed? Technically, other than the factory holes not lining up, there's no particular reason you can't use the 71-72 assembly. Just keep in mind you will have to make some modifications to make it work. As for lining up with the carb, it's a cable operated system and the cable is lined up by the bracket that attaches to the carb, so the orientation of the cable from the firewall is less important.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
