![]() Join Date: Dec 2003
Heavy gauge battery cables.
Has anyone ever made their own cables from 1/0 or some heavier than factory cable?? My truck didn't come with any cables and i didn't know if any vendors made a non-factory top post style cable set? I'm going with an LS swap and i want to make sure i have a good supply of juice for all the goodies i'll be running.
https://www.ebay.com/itm/29620574751...mis&media=COPY |
#2 | |
Re: Heavy gauge battery cables.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
Might also try a place that sells HD truck parts. Most of your 18 wheelers use 00 cable. Some can build to length as well.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
![]() Join Date: Feb 2016
Yes! It is a great idea. Here is a link with some info on the subject. There's lots of others on sizing and routing. Just do some searches.
http://67-72chevytrucks.com/vboard/s...d.php?t=747881
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
After some resistance, I made my own battery cables. It was very easy.
I bought #2 gauge cable (red and black in color) from a NAPA store, using the old pieces as a length guide. Mine turned out overly long, I'll trim those back and recrimp. I bought the end pieces at NAPA also. My father has a crimper, the thing is huge, lots of leverage, that he bought back in the 1960's when he was an electrician in a coal mine. Personally, I would use something like that if I were you, but the impact crimpers are much cheaper (the tool dad has would cost several hundred dollars today). I found red and black heat shrink, glue lined, on ebay.com. That stuff is the bomb! The glue lining melts around the cable as it shrinks and conforms.....it permanently seals moisture out. I used a carpenter's knife to trim back the insulation. NAPA and I estimated what gauge to use based on how thick the wire cable looked on the old ones. #2 is much thicker than recommended, which should allow even more electrons to flow. I went with new battery terminals, let me find what I went with. I like the terminals and the process so much, I want to do it to my daily driver Honda next summer to make the yearly cleaning of cable ends and battery terminals much easier. https://www.oreillyauto.com/detail/s.../08805/4742296 Just search youtube for crimping videos, here are two good ones but I didn't have any fraying issues. https://www.youtube.com/watch?v=DlqUFPGU6C4 https://www.youtube.com/watch?v=mBSnfHhi5xA I used a heat gun to shrink down the heat shrink, I locked the newly crimped cable in a bench vise and then used a heat gun I bought to remove old vinyl floor tiles some years ago. It worked very, very well. No need to buy or use a torch of any kind. I did a practice run on some rebar my dad had laying around. One thing I would do differently. Crimp on and seal one end, then mount that to your starter or engine ground (depending on which wire you are doing first). Then run that to your battery, allowing the cable to align itself how it wishes as it will twist to its most comfortable position. Then mark how the cable end will go. Then remove insulation, put on heat shrink, crimp end, and shrink heat shrink. If you do not, the terminal end will likely be turned a way different than how it wants to lay and you'll have to fight that when you put the cable end onto the battery terminal. I'll be able to fix that when I trim my cables down. Somehow my new cables are about 6 inches longer than they need to be. Be sure to clean your mounting points on starter and ground very well with a wire wheel (Dremel Tool) or brush and then use some dielectric grease to stave off corrosion. A crimping tools I would have bought if I dad didn't have that big crimper. https://www.amazon.com/PENSON-CAYQK0...+crimping+tool https://www.summitracing.com/parts/l...SABEgK67fD_BwE |
Old member
I haven't used them for my truck but I have used them for a few golf carts. I have a 6ft set going on the ramp truck for the winch if I ever get around to do it.
#2 AWG 3ft. https://www.harborfreight.com/3-ft-i...awg-63748.html 6ft. https://www.harborfreight.com/6-ft-i...awg-63747.html ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
So,, what else you got???
![]() Join Date: May 2010
I make lots of custom battery cables at the real job. They are kind of pricey, but they are just what the customer wants/needs for their particular applications.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks.... Sorry, we CANNOT ship larger parts. Thanks.
If you are redoing them, always a good idea to add one extra heavy gauge between the motor and frame.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#9 | |
Greg
________________ 1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd. 2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold} 1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400 2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax. |
Just remember that not all cable is created equal.
I got a killer deal on some heavy gauge wire. I ran into sporadic cranking issues. One day I was trying to figure out what the issue was and brushed against the wire and practically got burned by how hot it was. I ended up going down to my local welding shop and bought some welding cable and lugs. After redoing the cables it fires like a champ every single time.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
