Source for Carpet?
Has anyone had luck in finding a decent carpet kit? I'm at that stage in my retromod on a '65 and want a good quality carpet
Re: Source for Carpet?
After investigating this myself, I found most carpet is made in the USA by A.C.C. (Auto Custom Carpet). From there it gets sold thru different vendors. Bearing that in mind I simply looked for the best deal, verified it was made by ACC, and made my purchase. I chose the "mass backed" option so it was a nice heavy chunk o' carpet. It wasn't a perfect fit as it was a tad narrow at the kick panels. However, it was close enough for the money and usage I put it thru. The pic shows where it came up short. It's a little better on the other side, and it could have just been the installer (me). Whatever though, it was my first try. My second go-round in my longbed came out closer but still has that gap at the divot in the kick panel.
Moderator
![]() ![]() Join Date: Aug 2011
This is my plan - https://www.stockinteriors.com/AutoC...=31&ModelId=88
#4 | |
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
It's Better With Nitro
I used ACC carpet kits on my last several projects, including a 63 Tempest and Riviera restoration projects, and my C10. Stock Interiors has some of the best pricing along with the largest selection of color and type. Here's the ACC carpet that I recently laid out in my cab.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#6 | |
Moderator
So was the kick panel area narrow? Did you buy it with the mass backing? Says it's 40 mil thick, I believe thats .040 thousandths? almost 3/32" 1.1 millimeter? doesnt sound like much but I dont know.
I didn't get the extra backing (I had installed sound and thermal barrier on the floor of my cab). The width of the carpet in the footwell area from kick panel to kick panel was perfect in my case. I had to glue a couple of small pieces of what I trimmed from the width at the door sills in the little divot area at the floor/kick panel transition between the door opening and vents.
#8 | |
Yes, ACC kit from Stock Interiors. The back panel carpet piece works well, but I would recommend using additional industrial strength velcro in the low spots. Let it set in the sun for awhile before installing it to get the carpet to relax a little so it will form around the corrugated pattern (same as I did for the main carpet piece) a bit easier.
![]() Join Date: Jan 2011
I have the ACC stuff in my 66 and it has held up pretty good with 4 years of daily driving.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: May 2011
ACC is the best available. Everything else (imported) is junk.
1960 Chevy Apache10 Short Fleetside 1961 Chevy Apache10 Short Fleetside 1961 Chevy Apache20 Fleetside 1963 Chevy C10 Short Fleetside 1965 Chevy C10 Short Stepside 1965 Chevy C10 Long Fleetside 1966 GMC 1000 Long Fleetside 1966 Chevy C10 Short Fleetside |
Just installed my Stock Interior carpet! Great fit and Quality but I can't seem to figure out the right way to install the rear cab carpet
#15 |
![]() Join Date: Sep 2006
Check www.rockauto.com . They have even better prices then stock interiors. Same ACC Carpet. I just ordered some for my Mustang. It was $183 shipped and that is the carpet with Mass Backing. Without Mass Backing It would be around $140 shipped. I got the 80/20 loop https://www.rockauto.com/en/catalog/...,flooring,1264
https://www.rockauto.com/en/moreinfo...492233&jsn=421
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#16 |
Moderator
Buyer beware.
#17 |
It's ACC Carpet. If you want to save an extra 5% use this code in the "How did you hear about us" box 9594760291389246
#18 |
![]() Join Date: Feb 2013
I'm happy with the quality of ACC carpet from Stock Interiors but it's about 1/2" too narrow in the foot well area on both sides. It's not noticeable in the picture because I also used the ACC kick panels. I had to add a 1/4" shim behind the bottom edge of each kick panel to close up the gap completely. The carpet is not laying completely flat in this pic because I had just completed the install. The carpet flattened-out quickly.
#19 |
Moderator
I called the a few weeks ago about they're being too narrow. They stated that's the way GM did it so that's the way they are doing it. Did these come with carpet? And too narrow?
#20 | |
The kick panels came with carpet. Even with the carpet, they are only about 1/4" thick which is not enough to close up the 1/2" gap at the edge of the carpet. This is why I had to add a 1/4" shim behind the bottom edge of the kick panels. Last edited by mfm3; 11-11-2018 at 05:07 PM. |
#21 |
60-66 Nut
To my knowledge, these trucks did not come from the factory with anything other than a rubber floor mat.
Tags |
carpet |
