![]() Join Date: Aug 2017
Air Ride Suggestions
Happy Friday guys. I have a few questions to help me put the final touches on my air ride kit before ordering. I want to make sure I have everything in order.
I have a 1965 C10 SWB on stock 15x10 and 235/75/15 tires, when I bought the truck I completely replaced all of the suspension components knowing that I would go with air-ride soon. All bushings, bump stops, tie rods, upper and lower ball joints, shocks, bearings, brakes (drums) have all been replaced. Needless to say I want to stay with the drums because my brakes work like a charm and well its all new (plus I have two kids and we all know how expensive those little turds are) Here is the plan: EZ Classic Air Ride Kit (one 444c Compressor) Cupping the lower control arms No C Notch (I'm not a fan of cutting up the truck) So the last thing I'm trying to figure out are the shocks. Should I do a shock relocation kit (front and rear) since my shocks are new? Or should I just buy shorter shocks and use the stock location? Also I know I need to buy an adjustable track bar; any suggestions? Lastly what size tires are best? I'm looking for white walls but with a 10" wheel I've been going back and forth. If you have any pictures please feel free to share. I'm not looking to build anything crazy I just cruise to local shows and put around town in it. Not looking to build a hot rod or trailer queen. Just something safe for me and the family to enjoy and spend time together around town. I appreciate any and all help. |
Re: Air Ride Suggestions
I guess you're not wanting to go much or any lower than stock since you don't want a C-notch and you've kept the bump stops?
If you're not going low then you can keep the stock shocks/locations. If you're wanting to go low then you'll need a C-notch and to remove the bump stops and brackets completely. You'll also need to relocate the shocks front and rear. Bag brackets aren't needed in the rear, you can bolt D2600 bags straight to the frame and trailing arms. You won't need lower cups up front if you're cupping the lower a-arms. FrizzleFry's post on relocation the shocks is the best way I've seen. I did this on my '66 and it rode and handled great. http://67-72chevytrucks.com/vboard/s...postid=4730005 Tire size depends on how low you're going. On my '66 with a 5.5/7" drop I used 215/75-15's on stock front wheels, and 235/75-15's on 8" rear wheels. Your 10" wheels will be too wide up front if you're dropping it much, and may be too wide in the rear. ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#3 | |
![]() Join Date: Jan 2015
Is that C notched? I want to lower mine but don't want to do anything to mess up bed space. |
Only a small pipe notch, nothing that gets into the bed floor.
#6 | |
BaBaBooey BaBaBooey ![]() GO SPURS GO!!! |
#7 | |
Thank you for the reply and I love your truck. I do plan to go low and plan to remove the bump stops and brackets during install. Also thank you on the suggestions for the shock brackets. Looks like I have some more work to do before installing my air ride.
That's a crate with a VW long block in the back and it didn't bottom out. Depends on how low you go and what springs you use. Or just run bags and add more air.
I would contact Travis at AZ Pro Performance. They will have everything you need and he has built a few of these trucks on this forum. Here's a similar air ride kit they sell:
http://www.azproperformance.com/Budg...63-72-C10.html Here is a good trac bar, rear shock relocaters and C notch if you need them. http://www.azproperformance.com/Dead...age-63-72-C10/ |
#11 | |
-Andrew |
67-72 parts collector,…
![]() Join Date: Nov 2002
This is a good thread to read:
http://67-72chevytrucks.com/vboard/s...d.php?t=575686 Member way2lo2 has an eBay store. Look for Streetmachinery Boris has been bagging these trucks probably longer than anyone. He can sell you these basic kits or Ridetech or Airlift products, all the way up to a full RoadsterShop chassis.
#13 | |
![]() Join Date: Mar 2004
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
Thank you everyone for the help.
