AC with Vortec heads
I have an 84 GMC 1500 and am considering Vortec heads. Will the factory ac brackets bolt up to a Vortec style intake or will I need to figure something out?
Re: AC with Vortec heads
the vortec heads have the same 3 bolt hole set up on the front of them as the older Gm heads so you should be fine
Grandpas and Dads and now my 1965 C-10 1975 SWB C-10 |
the intake you will be running with the vortec heads has 2bolt holes for the a/c compressor bracket if you have that style I ran the vortec heads on my 79 with no problems you should be ok
4x4k30 if trouble was money i would have plenty |
That's good to hear..I wasn't sure since the Vortec manifolds have less bolts.
| Bookmarks |
