12-03-2017, 03:46 PM | #1 |
Electric fan thermostat temperature sensor switch
My son has a 69 C10 with a electric fan. He mounted the temperature sensor switch on the passenger side of the block. Today he noticed that the wire to the sensor switch is fried. Due to the wire hitting the headers. Is there another location he can move the sensor switch to? So he wont have this happen to him again. Can the sensor switch be moved to the housing for the thermostat?
Looking for suggestions. Thanks, Ramiro |
12-03-2017, 06:10 PM | #2 |
Re: Electric fan thermostat temperature sensor switch
He can put the the sensor in the radiator if it has a boss for it.
12-03-2017, 11:18 PM | #3 |
If a V8 there is a hole/plug on the outer left side of each head and depending on the intake manifold there maybe a hole/plug on the crossover to the thermostat. Speaking of thermostats there are thermostat housings with a hole/plug built in as well.
12-04-2017, 02:08 AM | #4 |
All about them K’s
I put mine in the intake. Works perfect.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
12-04-2017, 10:39 AM | #5 |
Thank you all for chiming in. Look like we install it in the intake. Thanks again.
Ramiro |
