Carpe manana
![]() ![]() Join Date: Dec 2010
Let's play name that part, bolt, harness, screw....
I figure this could be a good learning opportunity. Let's post up parts and pieces and name the application. Here's one: where does this rubber piece attach?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Let's play name that part, bolt, harness, screw....
Airconditioning housing for condensation drain?
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
![]() Join Date: Apr 2008
a/c evaporator drain and spring clamp
old money |
Carpe manana
Yes! Often missing. Here's the attachment location.
Carpe manana
Ok. Anyone familiar with these sheetmetal screws?
grounding strap screws
Carpe manana
These are the body-side ground screws that I'm familiar with - not all used a star washer but that's just my experience. Here are examples including that for the ground for the AC harness at the condenser box and those at the rad support, which differ from that below: http://67-72chevytrucks.com/vboard/s...1&postcount=54
The longer sheet sheet metal screws above were used for two applications that I'm aware of.....
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 12-08-2017 at 11:59 PM. |
Carpe manana
These are the screws used for the fan ground at the AC box and examples of those used for grounds at rad support. Replated in clear zinc.
Carpe manana
Here's the screw used for the battery clamp on my blue 72 blazer - similar to rad support ground screws but longer.
Carpe manana
Screws in post #5 are correct for mounting the console to floor pan and also used for some attachment points for AC and heater box - in cab side maybe?
Carpe manana
Ok. What about these screws....anyone?
![]() Join Date: Nov 2014
Here's a hint...Some Blazer and Jimmy guys will have these others will not.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
![]() Join Date: Jun 2010
Rear hatch screws?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Carpe manana
Close! These are the top bolts for use on k5s w a single wall top. Not best example pic but shown below.
#15 |
![]() Join Date: Feb 2009
Since no takers, I'll guess tire carrier. If those are 1", nearest screw I have is for the LH inner fender brace, but they have spin washers.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#16 |
Carpe manana
How about the application for these nuts?
#17 | ||
"I ain't nobody, dork."
Acorn nuts for West Coast Jr. mirrors.
Gary
#18 |
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
#19 |
Carpe manana
Yes! Camper mirrors and below eyeline. Did you know the threads are metric?
#20 |
Carpe manana
Here's an obscure part (set of 4) I received in a parts lot. I honestly don't know exactly where these go. Spacer for what the rear lamp lens?? Between screw and lens?
#21 |
![]() Join Date: Feb 2016
If that's what I think it is I wish I had a 5 gallon bucket full of them. 72 c10 part 2 per vehicle
#22 |
Carpe manana
What do you think they are???
#23 |
![]() Join Date: Jul 2015
And I thought you were posting about the screwing I sent you!
#24 |
Vent window screw on inside of door? The one you can see just below the window.
I got all excited and answered before reading whole thread. HA. This is fun, good idea! Last edited by elkniks; 01-23-2018 at 09:18 PM. Reason: cause I'm a big stooopid. |
#25 | |
![]() ![]() Join Date: Sep 2008
Two per side.
