12-09-2017, 03:29 PM | #1 |
My Dream 1950 Chevy
I call it my Birth Control Truck, I already have 6 biological children and my wife has 2 from a previous marrage, but i,finally found my dream vehicle it's a 1950 Chevy 3100, it needs work but I feel that I got it at a very reasonable price.
Posted via Mobile Device |
12-09-2017, 03:30 PM | #2 |
Re: My Dream 1950 Chevy
12-11-2017, 09:05 AM | #3 |
Nice! If your happy that's all that matters, it's your truck. Good luck, looks like you have some good parts there.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
12-11-2017, 10:45 PM | #5 |
Plan is to clean out the garage first, that's almost done. Separate the body and take inventory of what I have. Plan is to start from the ground up, chassis first refurbish that and get it painted, then update the suspension
12-11-2017, 11:23 PM | #8 |
Yep S10 is there already, so that eliminates a step for me, just want to clean it up really nice and start replacing with new suspension, I was thinking coil over for better ride, bagging it is just too much out of my wallet.
12-11-2017, 11:57 PM | #9 |
part of the reason the wheels look so far in is because they are super positive offset, like for a FWD or 4X4. if you intend to keep them, you will need spacers even with a 4x4 axle.
good start, but what is actually holding the cab on? I dont see any body mounts
12-12-2017, 12:35 AM | #10 |
Yep the body is just sitting on top of the chassis, the seller literally just set the body on top, it's close but not exactly where it needs to be.
12-13-2017, 12:29 PM | #11 |
An odd note I recently found in trying to get my truck ready for PA registration...spacers thicker than 1/4" are not allowed. So a correct track width rear end might be the way to go. (Subchapter E 175.65 (h)) Yep, I'm the nerd carrying around the PA registration paperwork trying to check it all off before paying for an inspection.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
12-13-2017, 04:21 PM | #12 |
I think they mean spacer spacers, like the kind you slide over the studs but still use the studs. at least that is what they call a spacer in kansas.
12-13-2017, 08:27 PM | #13 |
Well I just pulled out all the extras for the truck and I must say I just had X-Mass early but there are some things that are missing. But there is a lot i don't need to purchase.
12-13-2017, 11:37 PM | #14 |
Well looks like the paperwork is from Michigan originally so shouldn't be too much hassle to have that transfered here to pa and updated.
Looks like from all the patch pannels and extras that he had the cab is pretty much covered, he actually just offered me a manifold for the engine that's in the truck now. I will say that the floor and about 1/4 to 1/2 of the firewall is missing rusted off. He said 2 of the pannels he had were for the floor but I wouldn't know myself just by looking at them. |
12-13-2017, 12:22 PM | #15 |
Ha, I didn't realize you already bought it. Alrighty then, here we go!
12-14-2017, 05:52 PM | #17 |
I will be getting manuals ordered by the weekend, yes there is still some things missing, like mainly the grill. But hopefully once I have the manual, and a new welder, I will get to cracking on the frame and body, I will be dropping the rear end to do the flip flop on the frame it is a shortbed s10.
12-14-2017, 06:39 PM | #18 |
I bet the guy has the grille on the wall in his garage haha. they are super popular wall hangers.
12-14-2017, 07:33 PM | #19 |
That's a $350.00 dollar piece of art that needs to be on the front of a truck
12-15-2017, 02:05 PM | #20 | |
Don't skimp on this tool. You'll use it a ton!
12-15-2017, 04:59 PM | #21 |
Yea I was already looking and I'm up in the air right now, that's one thing I know I will be dropping some cash on but I will be using it a lot.
12-15-2017, 05:16 PM | #22 |
I like the lincolns, 19 years ago for my birthday I bought a Lincoln 170T which is the same as a 170 plus with MIG but without infinite adjustable heat (it has 5 or 6 click settings). since then I have worked on about 30 trucks with it. it makes anyone look like a pro, its very confidence inspiring.
a lot of guys like Miller too, which I think is a good brand if just a little overhyped, and I have heard that Hobarts are Miller guts, so they are good too. I say get a 220V MIG setup because you can always turn it down, but you can never turn a 110 flux UP. MIG is so much nicer for sheetmetal too. dot. dot. dot. dotdotdotdot. dot. oh look I am 1% done. :\
12-15-2017, 06:02 PM | #23 |
That's primarily the brand's I was looking at, biggest problem I have is that I don't have 220 in the garage but I could pull it from my laundry room.
I was looking at floor pans today, with the floor and part of the angled part of the firewall missing would it be worth it to purchase a complete floor pan to save time? I started to to look at pullys, alts, starters, ext. For the engine I need to get this truck running anyone have a good resource to look at for the smallblock? |
12-15-2017, 08:21 PM | #24 | |
12-15-2017, 08:35 PM | #25 | ||
just being real with you. I want to see it finished as much as you do, I love seeing these old trucks cruising around.
