![]() Join Date: Aug 2010
Spare Tire Carriers
So I have my eye on a factory style spare tire carrier that goes behind the rear seat. And the one I am looking at has a few minor differences from the tire carriers I’ve seen on this board. The owner claims they make two different types of spare tire carriers but I can’t seem to find any matching this type. What do you guys think? It looks right to me but I don’t see a slot for the hub bolt and the other examples I have seen have a pressed in raised area at the slot and this one is flat all the way down. I also see an extra hole on the base legs.
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 Last edited by Graham57a; 12-16-2017 at 12:20 PM. |
Re: Spare Tire Carriers
Pics for comparison
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
![]() Join Date: May 2006
what size tire are you using?
If I remember correctly from my 71 Blazer, you might have difficulty trying to fit a 31" tire with the inside rack in the original position.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
'71 here with 31's; it is a bit wonky.....
-Bruce 1971 K5 Blazer 4WD ![]() |
Carpe manana
![]() ![]() Join Date: Dec 2010
Not certain but I think that some GM vans used a spare tire mount very similar to first gen k5s. Did second gen k5s use a similar mount as well?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Square body’s use a round tubing mount over the right rear. At least the ones I’ve seen
Pretty sure the early square body ones, maybe the full removable top trucks used a similar mount, which may be what this is.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 12-16-2017 at 07:54 PM. |
The truck I posted is a copy I believe of the Blazer in Jaws. This is a screen shot. I don't think they would put a tire in a truck in a movie just because.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
I was thinking rear view blocked by a big tire
#13 | |
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
Bringing back an old thread to see if this was ever figured out. Looking at one identical to the one the OP was looking at. Can anyone confirm if this is from something other than a 69-72 Blazer? It doesn't look like you could adjust to a bigger or smaller tire with the fixed bolt location.
My LS Swap: http://67-72chevytrucks.com/vboard/s...d.php?t=718573 |
#15 |
Active Member
![]() Join Date: Mar 2016
Hello My dad work on the Assembly Line for GM in the 1970s and we talk about the spare tire holder he Alway said a blazer only had the two hole and a suburban 3 hold for the floors where made of wood and need more support , I hope this help
#16 |
Roadtrip!
![]() Join Date: Feb 2003
The suburbans had a well on the pass side to hold a spare tire.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#17 |
Here's mine. The legs look similar but the slit in the middle of yours looks completely different. I've never seen one like that before.
![]() 1972 GMC Jimmy 6.0/4L65 1972 Chevrolet long bed 1/2 ton |
#18 |
I bought one like the top one from a forum member. My guess is it is out of a van or newer blazer. It works fine with my stock spare and the only difference I see is that the bolt does not have the slot adjustment.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
