12-17-2017, 06:57 PM | #1 |
Another L.E.D Turn Signal Problem
Ive searched the web and this site, but cant seem to get a straight answer.
ive been running Regular bulb up front with led tail-brake-reverse lights for years (with a standard flaser 10+ years) i installed led front lights and bought one of these https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 wired up the ground and no flash/blink lights (parking) are on solid the new flasher has the same pin position as the stock one i pulled out old flasher says (HEAVY-DUTY FLASHER FUSE INPUT LEAD) new flaher says(HEAVY DUTY INPUT LEAD MUST BE FUSED) Any idea's Thanks (truck = 1970 gmc)
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG) |
12-17-2017, 07:46 PM | #2 |
Re: Another L.E.D Turn Signal Problem
I thought needed a 3 prong
Stan 67 swb BLU MULE posted via flip-fone |
12-17-2017, 08:02 PM | #3 |
Old member
They make adapter for the flasher to swap polarity to make them work. LED are polarity sensitive where the regular bulbs are not. It could be the grounds also on the front turn signal housing not making good contact.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-17-2017, 09:38 PM | #4 |
if their were bad grounds wouldnt that prevent the parking lights from working?
my parking ligts are on solid. just dont blink.
12-18-2017, 07:10 AM | #5 |
Old member
Not necessarily. They are separate circuits but I think the problem is the polarity.
12-18-2017, 08:35 PM | #6 |
So I just made some short leads to test. (Flasher is plugged in opposite) still solid no blink. This is the electronic led flasher /w ground wire
12-18-2017, 02:37 PM | #7 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-18-2017, 10:22 PM | #8 | |
Tested. Solid leds polarity is just reverseing the pins while plunged into fuse panal right? I made some short jumper wires and switched the pins and put the flasher ground to the dimmer mounting screw. Tested. Solid leds
12-20-2017, 06:27 PM | #9 |
FIXED
ok long story short my flasher set up as follows THE HAZARDS FLASHER a electronic flasher with polerity reverser installed (with ground wire grounded) THE TURN SIGNAL FLASHER a electronic no load "reverse polerity" flasher (no ground wire) this is the original flasher i baught and tried but did not work. THE PROBLEM = becouse i did not have a hazard flasher i didn't realize my hazard button was set to on of course the blinkers didn't blink. i just tested this theory and thats what it was. You know sometimes my blonde hair makes me not think clearly lol.
12-20-2017, 10:05 PM | #10 | |
Old member
Robznob11, we got nrb's70gmc fixed up.
12-20-2017, 10:49 PM | #11 | |
In my defence I did mention I'd never had a hazard flasher installed. No one ever mentioned make sure your hazard button isn't on. Lol I sure did fill like a ra-tard when I figured that out
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG) Last edited by nrb's70gmc; 12-20-2017 at 11:21 PM. |
12-21-2017, 08:35 AM | #12 |
Old member
That's what my post was for when I went out and checked mine. I had thought maybe this was it.
We have all been there. Don't feel bad it's just part of the game.
