Old 12-19-2017, 05:17 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Polishing clear anodized aluminum grille without stripping
I picked up a 72 grille and it's super. Not a flaw less one hairline scratch very much on the surface. You can't feel it. As luck has it the scratch is in good spot. You'd have to be looking for it or a half-pint.
But I'd like to polish it out if possible. Has anyone had success polishing any level of scratches without harming the existing surface? I've read many times that NOPE, you have to remove all the anodize and start over.
I described the scar to Eastwood for "Autosol Anodized Aluminum Polish."
They said "That product would certainly remove the scratch out of the grille on your vehicle."................................The description and label seem to be a contradiction "Anodized Aluminum polish" & "For un-coated aluminum surfaces". I'll probably buy a tube and test on the spare.
Here's another product I'm inquiring on. It's for oxidation anyway, on what he describes as very hard anodize. I don't see that tool on the grille though. the scratch is not on a flat surface. But a Dremel may work. https://mercedessource.com/tech-help...um-window-trim
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-19-2017, 05:22 PM   #2
demian5
demian5's Avatar
Re: Polishing clear anodized aluminum grille without stripping
You will need to sand the clear off and polish it.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 12-19-2017, 05:31 PM   #3
71CHEVYSHORTBED402
I reject that answer
Tony
Old 12-19-2017, 06:40 PM   #4
demian5
demian5's Avatar
You cant clean the garage standing outside, with the door closed...
1986 C20 Scottsdale
Instagram: C10sofOC
Old 12-19-2017, 06:43 PM   #5
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-19-2017, 06:44 PM   #6
71CHEVYSHORTBED402
Can too.
When people say strip & polished, the polish is a cleaner an moderate protector right? Seems you'd want to seal it somehow.
I heard back from the Mercedes folks "I am not sure if our trim polish would work on this trim we have never tried it on a Chevy trim you could send some pictures and we could try and determine if it is the same as the Mercedes"
Tony
Old 12-19-2017, 06:48 PM   #7
demian5
demian5's Avatar
Can too.
No, it is a clear spray coating.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 12-19-2017, 10:21 PM   #8
71CHEVYSHORTBED402
Not a one an acceptable answer.
Chrome is definitely bright. Powder coat is probably nice, I'd like to see that.
Tony
Old 12-19-2017, 10:30 PM   #9
jocko
jocko's Avatar
I've only seen a few pc'ed, and have yet to see one that rivals an anodized finish, let alone chrome. I'd leave it alone unless you're in the final 8 for the Riddler, THEN maybe...
Old 12-19-2017, 10:33 PM   #10
Grumpy old man
Grumpy old man's Avatar
Chrome on the left aluminum on the right
Old 12-20-2017, 12:39 AM   #11
71CHEVYSHORTBED402
Until now I figured the bezels were chrome to begin with. Never put much thought into it. Sick and tired of learning new stuff man...........Just kidding.
That's the ticket for this grille, though I may play with that spot. I can't complain, it will look sharp as is.
Originally Posted by beautimus View Post
try polishing compound on another similar part. then if it works try it on the good one. also you might try a good paste wax. My understanding (someone will correct me if i am wrong) is that anodizing is like clear coat that is electroplated on instead of sprayed on. if that is true, you should be able to fix it like scratches in paint. But if it were bubbling or flaking off, or cracked like on a part that were being repaired then i would say that is another matter entirely.
just suggestions, but that is what i would try first if it belonged to me. please tell us how it turns out and what you end up doing. and remember we love pics.
best of luck to you sir. Tony
Thank you. Woodstock, how cool is that?.................................I tried 3M chrome and metal polish that does amazing things with chrome. Tried a quality light abrasive paint polish. Tried some store bought more abrasive paint scratch remover. Tried some quality paint cutter...........The surface just laughed.
If you watch the Mercedes guy, he's tried near everything and ended up bottling his own. I did not use a power tool or anything that resembles an abrasive pad.......No way, not yet anyway.
My spare still has a nice hard finish. Plenty of scratches to choose from too, so I'll likely make a go of that using at least the first product in the OP, Autosol Anodized Aluminum Polish. If any scratch can come out it's this one, but at this point I'm real skeptical about Eastwood's response that it works. The finish is very hard, it's nothing like paint or clear coat.
Tony
Old 12-20-2017, 08:03 AM   #12
Grumpy old man
You could try this
https://sciencing.com/repair-anodize...s-7899695.html ,
Or just hand it to the chrome shop ?
Old 12-20-2017, 08:10 AM   #13
Grumpy old man
I thought all this was supposed to be fun ?
Old 12-20-2017, 09:53 PM   #14
71CHEVYSHORTBED402
You could try this
Interesting.
Chrome shop does chrome, so nah.
Sometimes it's just not that fun. Keeps the brain going at least.
Tony
Old 12-19-2017, 10:53 PM   #15
beautimus
beautimus's Avatar
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 12-20-2017, 09:14 AM   #16
StingRay
StingRay's Avatar
Anodizing is very very hard and incredibly thin. If you make it shine and remove the scratches you will have removed it all and polished the aluminum.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 01-11-2018, 07:17 PM   #17
rockyrivermark
Small foam brush
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 04-10-2018, 09:18 PM   #18
Hoodogie
Question I'm putting the truck back together and bought a new outer grill and head light rings can I just brush on the protectaclear from Everbrite to keep it shinny or to I have to do some special prep to the metal and how long will it last is this going to have to be recoated periodically like wax. thanks
Hoodogie is offline   Reply With Quote
Old 04-10-2018, 09:45 PM   #19
rockyrivermark
No. It should be chromed or anodized already.
No need to put anything on it.
My build page
Old 04-10-2018, 09:58 PM   #20
Hoodogie
eventually its going to fade like the old ones right? do I just need to keep it waxed up which I never did with the old one. I went on their web site and not sure if its worth buying their coating to put on new stuff that doesn't need restoration and if it is any better than a good coat of wax.
