Old 12-28-2017, 11:13 AM   #1
botoepfer
botoepfer's Avatar
292 motor mounts used in swap!
hello folks I am doing a bit of research on building motor mounts to drop a 292 in place of my 230,, love to see what you have done !
botoepfer is offline   Reply With Quote
Old 12-28-2017, 11:56 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 292 motor mounts used in swap!
There are a few people making the conversion mounts. Generally, you'll need to go with an electric fuel pump since the adapter plate covers the mechanical fuel pump location.
https://www.12bolt.com/store/p40/Ste...t_Adaptor.html
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-28-2017, 12:03 PM   #3
botoepfer
botoepfer's Avatar
Thanks vin63 I am trying to retain the mech pump,, But Tom Lowe has some cool stuff !
Old 12-28-2017, 01:18 PM   #4
T2vigil
T2vigil's Avatar
Don't know the right or wrong of it but I used a driver side motor mount and three 1" spacers. The spacers were made out of 3/8" galvanized pipe placed between the block and the motor mount. Poor mans fix and everything is straight and level. The benefit is being able to use the mechanical fuel pump.
T2vigil is offline   Reply With Quote
Old 12-28-2017, 02:19 PM   #5
botoepfer
botoepfer's Avatar
can you send me a picture please?
Old 12-28-2017, 04:36 PM   #6
T2vigil
T2vigil's Avatar
I stand corrected. The bottom two bolts are the ones with the 1" spacer. I do have photos takes today. All I need to do is find a way to add photos.
Old 12-28-2017, 04:38 PM   #7
padresag
just get the passenger side frame perch for a 292 instead of MM'ing it.
ron
padresag is offline   Reply With Quote
Old 12-28-2017, 10:05 PM   #8
padresag
mm stands for Mickey Mouse
ron
