Old 12-28-2017, 09:55 PM   #1
Hellbent
Don't blame the messenger
Hellbent's Avatar
Measurement request
Can someone please help me out with the measurement from the back wall of the cab to the first bed mount?
On the Level
Just a guy with a hammer and a grinder. OH!, and an HOA- enough said...: http://67-72chevytrucks.com/vboard/s...d.php?t=372525
"Some drink from the fountain of knowledge while others just gargle."
Hellbent is offline   Reply With Quote
Old 12-29-2017, 01:01 PM   #2
bigmac73
bigmac73's Avatar
Re: Measurement request
when I get home I will check it out , my bed is off
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 12-29-2017, 07:40 PM   #3
Lanman1972
Lanman1972's Avatar
I have a '71 with the bed removed, measurement is 2 3/4. I can send a pic if needed. Hope this helps.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 12-29-2017, 10:10 PM   #4
Hellbent
Hellbent's Avatar
Yes, that helps! Thank you very much. I’m sitting at 3 1/2”, maybe this explains why NOTHING is lining up.
On the Level
Old 12-30-2017, 12:53 AM   #5
rockyrivermark
That bracket steel is on an angle.
Best to measument form cab to center of bolt hole for more accurate placement.
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 12-30-2017, 11:58 AM   #6
Lanman1972
Lanman1972's Avatar
Pic! Just over 4 1/2 "
Old 12-30-2017, 03:40 PM   #7
Hellbent
Hellbent's Avatar
Great! Thank you all!
On the Level
