01-13-2018, 10:49 AM | #1 |
Hood won't "fit"!!!!
Just got my 74 K5 Blazer back on the road after a years resto. Last thing I did was put on the hood. It fit OK before I did body work and paint but now I can't get the rear to lay down far enough. The front is fine. I've dropped the hinges as far as they'll go and even took them off and hogged the adjusting holes out for more drop. Still won't lay down. I think the hinges are OK-they seem nice and tight. Has anyone ever used the Billet hinges? Would that help me out??
The rest of the truck came out awesome-I need the hood to fit and am at a standstill-HELP PS-I used fenders off a 79 but I believe they're identical to 74? PSS-I'll add some pictures later today of my problem
1972 Highlander PAC B 400BB-SOLD 1974 K5 Blazer-6.0 swap 1974 C20 Long Bed 454 1977 GMC HeavyHalf several adopted orphans |
01-13-2018, 11:03 AM | #2 |
Re: Hood won't "fit"!!!!
Lube your hinges
Yes the 79 is the same as 74 fenders.
72 2wd k5 blazer 86 c10 "Red",76 2wdK5 "Bertha",77 2wdK5 "48",79 c10"Buster" GONE |
01-13-2018, 11:36 AM | #3 |
Pictures-The hinges are well lubed
01-13-2018, 12:44 PM | #4 |
I put a nos hood on my 77 crewcab and it did the same thing its your hinge springs if they are not oem or if your fenders or not oem the holes in the hinges need to be sloted a little more to get the hood to lay down properly I had a good friend that does body work do it for me while I watched took about 20 mins I had a set of aftermarket springs that I used because the paint shop lost my orginal hood springs
4x4k30 if trouble was money i would have plenty |
01-13-2018, 01:46 PM | #5 |
The Blazer looks great! But I think you should just abandon it and I’ll sell. To me!! Lol
In all seriousness. It’s your springs. They’re probably worn out. |
01-13-2018, 06:40 PM | #6 | |
The easiest way to do that is to open the hood and have an assistant hold the front edge while you loosen the hinge-to-fender bolts. With the bolts loose, have your assistant push up on the front edge of the hood (that will pivot the hinges), then re-tighten the bolts. |
01-13-2018, 08:25 PM | #7 |
can you push down on the hood and make it sit flush?
There are stoppers in the cowl area that the rear of the hood rests on. they may need cranked down. but if that isnt the issue then read above posts lol
- When the Reaper makes his deal, trust in your steel - '77 C10 350/350 2/4 drop and a mild street engine |
01-14-2018, 08:44 AM | #8 | |
01-13-2018, 08:38 PM | #9 |
Did you put a new hood to coil seal on?
We had issues with our LMC coal seal holding the hood up. Switched to precision and it’s ok |
01-13-2018, 09:20 PM | #10 |
Lube the hinges
