Old 01-13-2018, 06:33 PM   #1
weider1717
sheesh which felpro 1 piece oil pan gasket do I need?
truck is an 87 4x4 350.
dip stick is passenger side and it looks like by reaching I need the "thick" gasket. I went to order my gaskets and saw they have one for a 1 piece or a 2 piece rear main seal.
what would my truck have came stock with? I need to know this before I order this gasket a long with all the others I will be needing. I take it order the 1 piece rubber oil pan gasket from felpro with a "steel core"?
thanks
weider1717 is offline   Reply With Quote
Old 01-13-2018, 06:36 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: sheesh which felpro 1 piece oil pan gasket do I need?
Your truck came from the factory with a 1 piece rear main seal engine.
95 S_Trucker is offline   Reply With Quote
Old 01-13-2018, 08:22 PM   #3
weider1717
anyone know the difference between the first two gaskets? one says thick front one doesn't one says rubber and steel core other just says rubber. Which do I need.
https://www.summitracing.com/search/...rder=Ascending
Old 01-15-2018, 08:17 AM   #4
95 S_Trucker
The first one should fit your truck. Its a factory replacement gasket.
The other 2 are for performance engines, where the timing cover may be different.
The GM/Delco part number is 10108676
Old 01-15-2018, 11:18 AM   #5
Rickysnickers
What you can do to be sure you have the right gasket is measure the oil pan. Since you are going to have it off, see how large the front semicircle is. That will tell you whether you need the thick or thin gasket. Also, even if you use one of those blue Felpro gaskets, use some sealant on the front between, the oil pan and the timing cover. I replaced mine a couple of times before realizing I needed to do that even though the instructions stated not to.
"place a straight edge across the pan rails, meas. down to the bottom of the lip-if the meas. is 2 3/8", use the thick seal, if the meas is 2 1/4", use the thin seal
they made a seal change"
Old 01-16-2018, 09:26 AM   #6
Desert1957
Desert1957's Avatar
Here is the Felpro kit I used on my 87 5.7 , Worked great NO leaks.
OS34500R
Desert
Desert1957 is offline   Reply With Quote
Old 01-16-2018, 09:37 AM   #7
Desert1957
Desert1957's Avatar
Sorry wrong pic , here is the OS34500R
Desert
Old 01-17-2018, 11:30 PM   #8
weider1717
thanks to all this site is great. I try to help others when I can to repay the favor
Old 01-19-2018, 08:53 PM   #9
Jake Wade
Jake Wade's Avatar
OS34500R is what I have always used, works great!
Jake Wade is offline   Reply With Quote
Old 01-19-2018, 11:08 PM   #10
xs-style
xs-style's Avatar
After years of doing it with the cork gaskets and a dab of rtv, those screw in gasket holders are wonderful lol
1978 Scottsdale - celebrating 10 years of teaching me profanity
1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold
1987 k5 blazer - sold... :\ seed money for the 81
1981 k20 4x4 - 5.3 swap in progress
Events attended:
Spring GOG 2011
Dale JR car show Summer 2012
Gathering at Tommys pickup parts
xs-style is offline   Reply With Quote
