01-14-2018, 05:23 PM | #1 |
No Limit X-Member Kit on a TF
No Limit X-Member Kit on a TF.
I'm going to post this here as I couldn't find any pictures or information about it other then the No Limit web site! The C-channel boxing plates and X-plates look like they would be a much stronger setup. My engine dynoed out with 517hp so it is a little bit more than the factory V-8. So I took and completely stripped the truck again, and started putting in the square tubing from one side of the frame to the other. I thought it would be smart to X everything, only to find out that it was a big mistake and it raised the passenger side rear corner 1/4 inch do to the welding of the last X piece, so I removed the X and everything went back to normal. |
01-14-2018, 05:31 PM | #2 |
Re: No Limit X-Member Kit on a TF
Next was cleaning and sanding inside of frame rails, then sealing with Rust-Oleum gloss black, then install.
01-14-2018, 08:42 PM | #3 |
Next is installing the X Bracing.
01-16-2018, 08:29 AM | #4 |
Thanks for sharing. This just gave me a great idea.
01-16-2018, 08:51 AM | #5 |
01-17-2018, 02:06 PM | #6 |
Looks like you did a nice job. You will be shocked at the ride quality improvement when you drive it again.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
02-19-2018, 08:47 PM | #7 |
I guess its time for some updating on the install!
Got it all welded up and the reinforcement bars removed. |
02-19-2018, 08:54 PM | #8 |
Then filling unneeded holes in the frame, sanding it and some sandblasting in the hard to get to places then paint!!!
02-20-2018, 12:17 AM | #9 |
Looks great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
02-21-2018, 08:29 PM | #10 |
