![]() Join Date: Jul 2015
396 Headers
Just wanting to know what any of you are running for headers on 396 engine in a 72 k10. My motor will be moved forward about 1 7/8 from the small block 350 location.
![]() Join Date: Feb 2001
Re: 396 Headers
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Re: 396 Headers
Darn site won't open.
![]() Join Date: Aug 2004
Re: 396 Headers
If you give up on headers, I bought these to go in a 72 that had a cracked manifold but eventually sold off that project and now have these in the parts board for sale. These fit excellent in our trucks.
John |
Re: 396 Headers
I've seen those ,but not sure which route I want to go. I'm not afraid to notch the frame a little.
Who Changed This?
![]() Join Date: Jan 2013
Re: 396 Headers
Sure are pretty. If they sold for $402, I might buy them. Not. Wow, that is expensive! I guess I have gotten used to the local pick-your-part yard.
#7 | |
Re: 396 Headers
I bought a set of Chinese big block Corvette manifolds to use in my short step but wound up buying Sandersons ceramic coated manifolds. Which are twice the price of those manifolds.... but I thought it was worth it.
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 396 Headers
I had a set of Chevelle BBC headers that came with my L34 396, didn't fit without cutting the transmission crossmember and wouldn't clear the automatic trans. linkage either, WAY over rated! Had to make a show in 72 hours so I ordered these, https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I placed the order on Tuesday, delivered on Wednesday! Still on the truck and rust free! Best deal out there! Ball and socket collectors and they came with gaskets and bolts! PS. They still dont leak!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#9 | |
![]() Join Date: Jun 2005
Re: 396 Headers
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Re: 396 Headers
Yep nothing wrong with a little shave off the frame. I actually built a 70 with a 383 stroker and used a set of Hooker Super Comps. I mounted the engine all the way back as far as it would go without firewall mods. I had to do minor clearanceing to the frame to get fit.
Re: 396 Headers
Is a K10 frame the same as a C10 frame? If so, use a set of Chevelle long tube headers and you can tuck the exhaust up inside the frame rails, but you will need a tubular trans crossmember and a custom or aftermarket shift linkage if you have an automatic.
Re: 396 Headers
If you are going manifolds, try and find the RV ones with the expansion joint in the middle.
http://67-72chevytrucks.com/vboard/s...d.php?t=197596
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Re: 396 Headers
I have an '85 cab and chassis truck with a 454 on it that has those manifolds. I think they are listed as stainless?
Re: 396 Headers
I put hedman mid length coated headers on my 402BB. Look good, sound good and fit without any cutting. Don’t remember the number of The headers but the mufflers are Dynomax ultra-flo welded #17221. My muffler guy recommended them for a big block and he couldn’t have been more right. I found them on amazon at a descent price
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 01-30-2018 at 08:36 PM. |
#15 |
Re: 396 Headers
Thanks...
#16 |
Re: 396 Headers
mine are Sanderson short headers
#17 |
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Re: 396 Headers
My truck had a set of Hooker headers in the bed of the truck when I picked it up. The PO had them ceramic coated after he yanked the engine and tore it down, but then decided to not redo the engine. I completed the engine build, and those headers fit perfectly. Long tube headers that do not drop below the frame. The label is still welded on, so I will see if there is a part number there that I can forward to you.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
#18 | |
Re: 396 Headers
#19 |
Re: 396 Headers
My Hedman 68198 just arrived. I've unpacked them and they look great! The gasket package has a picture of a 67-72 C10 on the front!
Again, these are for a 67 Chevelle BB and according to a few other posts on this board, they do not hang below the frame once installed.
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#20 | |
Re: 396 Headers
#21 |
Re: 396 Headers
Couple more for fun...
#22 | |
Re: 396 Headers
#23 |
Re: 396 Headers
Right!
I made the assumption that anybody willing to spend this much money on a set of these headers is going to do the research up front to ensure they're gonna work. Much like I did. Maybe that's a bad assumption. It's a good clarification though and one that is spot on. These headers, 68198 Hedman, require mods on the C10 to fit ( Auto tranny shift linkage and crossmember ). Hth, -klb
#24 |
![]() Join Date: Jul 2014
Re: 396 Headers
https://www.summitracing.com/parts/HOK-2463HKR
I'm running a set of these on my 454 in my K10. Engine crossmember is moved up to the next set of holes. No clearance issues
Chevy Runs Deep. 1956 210 LS1 TH350 3.31 Posi 12 Bolt 1969 Z/28 5.3 T56 3.73 Posi 12 Bolt 1973 Nova SS 355 TH350 2.73 Posi 12 Bolt 2000 K2500 Suburban LS 6.0 4L80 3.73 G80 2005 K2500HD CCSB LS 6.0 4L80 4.10 G80 2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic |
