01-26-2018, 04:24 PM | #1 |
67 k20 brake line frustration
Good day all
I am currently getting ready to swap out my axles for a set of 1976 d44 and a corp 14 . The problem I am having is locating a set of pre bent stainless lines for a 67 k20 w/power brakes either stock or setup for the disks The rear axle lines I have found for the corp 14 but nothing for the front Any info on vendors would be appreciated Thanks in advance Fyi stock height Last edited by Mts67C10K20; 01-26-2018 at 04:25 PM. Reason: New info |
01-26-2018, 04:45 PM | #2 |
Re: 67 k20 brake line frustration
You could use lines for a 71 or 72 with factory disc brakes, should drop right in. I'm not sure if the front brake hoses are in the same location on the frame so that may require some mods.
I purchased a complete set of lines from Inline tube, the front lines were the only ones that fit properly. (FWIW) |
01-26-2018, 05:31 PM | #3 | |
Thanks |
01-26-2018, 05:55 PM | #4 |
Get on the phone and give them a call, they seem to have all the lines you would ever need.
01-26-2018, 10:38 PM | #5 |
I ordered P/N CTB7144 (fitment for 71 3/4 ton, power disc brakes, 4x4, long bed)
01-27-2018, 04:16 PM | #6 |
BW
Thank you for your assistance an information Since Inline and the other vendors of brake lines that i called do not offer a set for a 67 K20 and are reluctant to suggest a different set not specific To an application Your help was exactly what was needed Everyone I've delt with on this board rocks 68ss thanks for the Texas insight |
